OMG....What just happen !!??? - Defender Source
Old December 31st, 2011, 01:00 PM
DucatiChick's Avatar
DucatiChick
Christine
1994 Defender90
Exclamation OMG....What just happen !!???
Drove home from a night out with friends, my D90 started to make a weird clunking/ tapping noise.
I had to back it up into the driveway and it was hard getting it in reverse...pulled forward a bit again to adjust my parking and tried to put it back in reverse when I heard ta awful crunching sound.
It starts right up and runs great....you can put it in gear, but the rattling and crunching noise returns AND it ain't going nowhere !! What just happen !!?? Is it my gearbox, drive shaft, tranny !!????
BTW..Happy New Year's everyone, from the looks of it, mine ain't gonna be so swell
Old December 31st, 2011, 02:09 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Sounds like synchos. Either way you gearbox has to come out.
Robert Deniro
Old December 31st, 2011, 02:17 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Check that you transfer case selector is in the proper location IE not between high and low or part way in N.
Old December 31st, 2011, 02:24 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Check everything external before ripping the gearbox out, could be the transfer box has been knocked out of gear,or a 1/2 shaft has let go. Does the hand brake hold OK?
Mike Hammond
Old December 31st, 2011, 04:56 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
could also me a rear diff
put it in lock and see if the truck moves
Old December 31st, 2011, 07:32 PM
mikeslandrover
Mike Hammond
Could be the front diff, front 1/2 shaft or CV joint too...
or it might be the gear box
Mike Hammond
Old January 1st, 2012, 10:23 AM
DucatiChick
Christine
1994 Defender90
I wiggled everything as far as clutch, gearstick, diff lock.... ( Hand brake held up )
Of course this happened Friday night, so now do to the New Years eve weekend...nobody is even able to look at it or give me an answer to what this could be...ugghhhh, soooo frustrating :-(
Old January 1st, 2012, 10:33 AM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
Where in Florida are you located?
Old January 1st, 2012, 11:31 AM
LRover's Avatar
LRover
J. Michael McCaig
From a safe distance get someone to watch the drive shafts while you try to drive off a short distance. If one of them spins freely (while hearing the crunching noise) then chances are the problem is in that axle that the drive shaft is connected to.
Old January 1st, 2012, 03:47 PM
T1G UP's Avatar
T1G UP
marcus
Puma 110 xs. Td5 110 xs for sale
put the difflock in and try to move it. if it moves then its a halfshaft, diff, or a cv.
if it doesn't and still make alot of noise......put an auto in
2011. 110 XS SW. 1999 TD5 110 XS SW Project For sale
Old January 1st, 2012, 07:29 PM
ron's Avatar
ron
Ron
call me I can walk you thru part of it, but Marcus is right its one of 3 my bet is the rear diff
seven eight one 6 for zero two 6 four zero
Old January 1st, 2012, 10:50 PM
the rover shop
shayne young
G'Day, just do yourself a favour, bring the 90 down to me to the Rover Shop in Ft Lauderdale, no mattter what it is i have the parts in stock to fix it...I can even let you take either the multistrada 1000DS, the Elefant or the monster or almost any of the other bikes around (as long as your 5'4" self can touch the ground) and you can make a semi vacation of it and pick your car up done when you are done...LOL....
Rangie conversion in the UK OMG Capt Milks The Flea Market 6 July 15th, 2010 06:06 PM
Ignition switch jumping jellyfish Defender Technical Discussions 1 October 15th, 2009 11:50 PM
For Sale Double Cab Land Rover Pickup Truck Pig Pen For Sale - Vehicles 14 February 4th, 2009 02:39 PM
Oil Cooler Line Parts List Wolf Fabrication Defender Technical Discussions 30 November 7th, 2007 12:29 PM
How often does this happen? Willh Misc. Chit-Chat 15 July 12th, 2007 08:37 AM
