OME suspension, and tires - Defender Source
Old October 8th, 2003, 10:07 PM
huntahdefender
Zak Slutzky
'94 D-90
hello, i have a '94 d-90 and i would like to put the OME HD suspension kit (springs and shocks), please any comments or thought, or any issues with install would be greatly appreciated, also i want to put the goodyear MTR's on what is the largest size i could put on? angain any thoughts or comments, thanks
Old October 8th, 2003, 10:29 PM
Toddco's Avatar
Toddco
Todd Klueger
1995 Defender 90
I used the OME 764 up front and in the rear I used Ome 762. This allowed for clearance of a 315/ 75/16 good year MTR 34.8" with a little rubbing here and there. I also replaced the driveshafts with high angle cv's. Now I run the same springs with a 1 1/4" spacer in the front and a 2" spacer in the rear and 37" MTR's on 15X8" wheels.
Old October 9th, 2003, 09:47 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
What kind of wheel'in are you planning to do?
The most commen and basic setup for biggeners is OME 751 front and OME 764 rear. With this setup you don't need longer brake lines or CV drive shaft but you might get some vibration, it's random. Shocks you can go with OME unless you are looking for extream suspension travel.
With this setup you can go with 285/75/16 on stock wheels.
Let us know how much lift you want, what size tires you want to run, and how much $$ you want to spend.
World traveler
Old October 10th, 2003, 03:29 PM
huntahdefender
Zak Slutzky
'94 D-90
hi, i live on the east coast so most of the wheeling i do is on old logging roads, ( deep ruts, muddy, stumps), but i am know goign to college in gunnison colorado, so i will be using my rig to get to good camping, and climbing spots as well as maybe hitting some real wheeling trails if i get the chance, i would like to beable to fit about 33's, but if i can fit bigger i might think about it, i want to try to avoid doign any gearing, and other major changes. right now i am looking at the OME HD kit from rovers north,http://catalog.roversnorth.com/catal...taf?id=omed90, price being about 675.00 with steering dampener, I also use my rig for construction, hunting, and search and rescue, so i will very commonly have fairly heavy loads in or being pulled by my rig. thanks for all the help
zak
Old October 10th, 2003, 04:14 PM
Tom Fitzgerald
Tom Fitzgerald
Hey Zak,
East Coaster here as well....I am running 751 frt, 781 rr springs. I carry a lot of gear/equipment, all the time. Probably 500 lbs+. The stance is good and handles great. You may need the Dbl Cardan DS in the rear, esp if you don't keep it loaded all the time. See Expedition Exchange's spring write up for some good descriptions and photos. I run 255-85 MT's, about a 33x10. I'm of the 'lbs per sq in' school of thought for traction. I was even able to adjust my steering stops in some, for better turning. I ran the Rubicon Trail in my 97 Jeep, twice, with a 33x9.50 tire. Drove it out, and back. It's plenty for all but the most extreme trails, even in CO. Just pick your line right! But that just doesn't sell those expensive tires! Just a little more grist for the mill! Good luck and let us know how you go when you decide.
Tom
tire, tires
Tires: an odessy souza Misc. Chit-Chat 37 December 14th, 2009 05:57 AM
2" OME Lift Before/After Pics pcscharfe Defender Technical Discussions 5 November 13th, 2007 02:09 PM
Requesting a little suspension advice nmc Defender Technical Discussions 9 March 19th, 2006 01:09 PM
OME and 285s scubadanster Defender Technical Discussions 29 July 9th, 2005 03:50 PM
OME suspension scubadanster Defender Technical Discussions 19 February 25th, 2005 09:37 PM
