OME shocks question (1995 D90) - Defender Source
Old April 23rd, 2014, 09:11 PM
ssi19's Avatar
ssi19
scott
1995/D90
I have OME shocks and springs (2" lift) and am about to convert to stock springs (no lift). I have been told by a few folks I can KEEP the OME shocks, even with genuine springs. Before I embark on this project, does anyone disagree? Thx in advance for any advice.
Old April 23rd, 2014, 09:16 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
If you stay on the road you should be fine.
Old April 23rd, 2014, 09:21 PM
jafir's Avatar
jafir
Jafir Elkurd
Are they plus 2 shocks? I'm pretty sure some of the ome shocks are standard length.
Old April 24th, 2014, 07:35 AM
ssi19's Avatar
ssi19
scott
1995/D90
hmmm. How could I check this? I looked and don't see any markings indicating the spring height/lenght.
Old April 24th, 2014, 08:42 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
How long have you had them? I imagine you could check your invoice or call where you got them for a part number.
Old April 24th, 2014, 09:01 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I had a 2" OME setup on my 90. Before I sold it I put the stock springs back on and kept the OME shocks. It actually rode very nicely especially when we got new tires for it. With the lighter setup of the ST and no winch/stock front bumper it had enough clearance for 285 width 33's (although I think the GY Duratracs run on the small side).
Old April 24th, 2014, 09:57 AM
jafir's Avatar
jafir
Jafir Elkurd
I don't know, other than what Zack said.
The part numbers for the extended shocks end in L
http://www.arbusa.com/uploads/PDF/ac...erDefender.pdf
Old April 24th, 2014, 10:07 AM
ssi19's Avatar
ssi19
scott
1995/D90
I don't know, other than what Zack said. The part numbers for the extended shocks end in L http://www.arbusa.com/uploads/PDF/ac...erDefender.pdf
Thanks all. Don't have contact with previous owner. But it sounds like it'll be ok to run this spring/shock setup.
Last question. If it turns out the shocks are a problem AFTER I put in the new springs, can I change the shocks without removing the springs again? (Especially those pesky front springs)
Old April 24th, 2014, 10:09 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Yeah, you could just pull the fronts out of the top.
Old April 24th, 2014, 10:24 AM
ssi19's Avatar
ssi19
scott
1995/D90
Zack, Jafir, Don - thanks
Old April 24th, 2014, 10:33 AM
OME do not make shocks that are longer than stock, do they?
Old April 24th, 2014, 10:35 AM
jafir's Avatar
jafir
Jafir Elkurd
They do, in that link I posted it shows that the part numbers end in L.
Old April 24th, 2014, 12:12 PM
If the studs for the shock towers break you will have to remove the front springs.
Old April 24th, 2014, 12:43 PM
Okay.... But simply putting in taller springs does not change the amount of possible axle travel.... So the longer shocks must work with stock. If not, they should be mandating longer bump stops.
The "L" models appear to be 20 mm longer compressed and 40 mm longer extended.
Old April 24th, 2014, 12:48 PM
jafir's Avatar
jafir
Jafir Elkurd
Agreed. That is the way things should work. Hopefully that is the case. But, as I think you suggested for me when I've asked about installing longer shocks, the best practice would be to measure things to be sure. I'm going to play it safe and get longer bump stops or spacers for mine.
Old April 26th, 2014, 07:00 PM
ssi19's Avatar
ssi19
scott
1995/D90
Swapped the springs today. Seems to be all good. Running real smooth.
D1/D90/RRC OME HD springs and shocks cupgt For Sale - Parts 2 June 11th, 2013 09:10 PM
Koni Heavy Track Shocks +2 - Land Rover - 4 New Shocks JohnC The Vendors Loft 7 April 13th, 2010 09:34 AM
OME 761 & 764 OME Sprins /Shocks for Sale SafariHP For Sale - Parts 6 December 12th, 2007 09:34 PM
D90 Fuel Tank/OME shocks rgrrvr Wanted 1 September 13th, 2007 07:31 AM
OME shocks- RRC vs. D90 Gore Ranger Defender Technical Discussions 0 May 1st, 2007 12:03 PM
