OME Shock Mount Question - Defender Source
Old August 10th, 2016, 11:48 PM
koshow's Avatar
koshow
Kenji
95/D90
Hello Friends,
Need some help here. Please note the current suspension setup is a Rockware full suspension kit (see photo). The mounting bracket for the rear shocks aren't compatible with the OME. Does OME have a bracket for the shocks? Anyone do an install that is familiar with this?
I don't know what the oem bracket is either. I have reached out to ARB USA but wanted to see if anyone here as some input.
Thank you!
https://drive.google.com/file/d/0Bw-...ew?usp=sharing
Old August 11th, 2016, 12:25 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
You should have an adapter on the lower shock mount. It coverts it to loop style. Just unbolt it and use the hole Otis in ,which is the actual original pin style shock mount, to mount the shock.
You might have a problem thigh because the rock ware hoops are made for extended shocks and the bilsteins that you are replacing them with don't spear to be. You can order some stock mounts and sell the rock wares or get longer shocks.
Old August 11th, 2016, 05:18 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Concur with Arcadeus; remove the adapter on the lower shock side and revert back to stock mounting brackets for the top given it looks like you are going to normal length shocks (or maybe +2's, which depending on what size spring you are running should work).
Someone will buy the rockware mount setup for sure.
If you need the OE upper mounts hit me on PM, I have a set sitting in the spares bin.
r-
Ray
Old August 11th, 2016, 10:44 PM
koshow's Avatar
koshow
Kenji
95/D90
r-
Ray
Thanks for the response. Called the dealer today and ordered OEM. Just wanted to confirm that was all I needed.
------ Follow up post added August 11th, 2016 08:44 PM ------
Thanks for the help!
mount
OME 761 and OME 764 2" Med Springs discojosh2000 For Sale - Parts 1 February 24th, 2012 11:11 AM
Lowered rear shock mounts, shock mount for spacers, and HLC Fab cones Jake1996d1 For Sale - Parts 3 October 13th, 2011 02:14 PM
Possible trade: OME 761/764 MD for OME 751/762 HD Scottg For Sale - Parts 1 April 24th, 2011 10:20 AM
OME HD Springs & OME Nitrocharger Shock Set Steve Friedman For Sale - Parts 1 January 24th, 2008 09:11 PM
OME 761 & 764 OME Sprins /Shocks for Sale SafariHP For Sale - Parts 6 December 12th, 2007 08:34 PM
