OME shock bushings? - Defender Source
Old April 1st, 2015, 09:53 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
OME shock bushings?
Any idea what a good substitute would be for the upper shock bushings (rear) ?
Neoprene, rubber, makes no difference, mine are just cooked with too much play.
Inquired what the cost of OME replacements were and first of all didn't have any in stock and second, they were stupid money ($40ea), so what else could I used?
Old April 1st, 2015, 09:55 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
how did you determine your bushings were done? visual? hearing squeaks? other? just curious, because i'm going down that road myself this spring.
Old April 1st, 2015, 10:00 PM
Jackie Treehorn
A
1985 (legitimately)
I've noticed rounding around the edges and what looks like excessive play. I haven't removed them yet, but they do look like they've seen better days.
The OMEs are positioned before the axle as a second set of shocks and what looks like stock Land Rover units in the back of the axle.Not that that matters, but just painting a picture for you.
Old April 1st, 2015, 10:15 PM
Jackie Treehorn
A
1985 (legitimately)
While I'm asking, who has done any touch-up painting on OME shocks?
Any off the shelf color that matches?
Old April 1st, 2015, 11:07 PM
toad's Avatar
toad
Cutter
I need some of these too but $40 each is crazy talk. I haven't started searching yet, but are they really any different than stock bushings?
Old April 9th, 2015, 03:38 PM
toad's Avatar
toad
Cutter
Mr. Treehorn did you ever find a source for these? Anyone recommend a replacement source, I don't care if they are proper OME I just want to get something so I can put the used shocks I bought on here on my truck and I need to get all the bushings, washers and spacers. Any reason why stock rover bushings wouldn't work?
Old April 9th, 2015, 04:06 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
mine are noisy too and driving me nuts
Old June 5th, 2015, 01:05 AM
671rover
671rover
94 d90
I replaced mine twice. Both times the bushings just broke apart and I was running without bushings. Realized it when I heard a loud clank whenever I go over bumps. I have these parts numbers:
OMEB36 (I think these are bushings for the rear shocks) MSRP $10.00
OMEB78 ( I think these are bushings for the steering stabalizer) $8.00
OMEB42 (I think these are bushings for the front shocks) MSRP $25.00
Old June 5th, 2015, 10:09 PM
doktorno
Chris deZ.
1995 Defender SW
Flat black.
bushings
Need to change front shock bushings leastonce Defender Technical Discussions 6 August 9th, 2014 06:14 PM
Why are top bushings being shredded on shock tower landrovernewbee Defender Technical Discussions 14 July 15th, 2014 01:02 PM
Shock bushings or new shocks dnp Defender Technical Discussions 6 August 30th, 2011 02:35 PM
OME HD Springs & OME Nitrocharger Shock Set Steve Friedman For Sale - Parts 1 January 24th, 2008 10:11 PM
OME castor correction bushings Overlander Defender Technical Discussions 3 January 4th, 2007 04:45 PM
