OME Lift Springs? - Defender Source
Old April 5th, 2004, 01:27 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
OME Lift Springs?
What is the maximum amount of lift you can get from an OME spring without spacers? Thanks!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 5th, 2004, 11:13 AM
ronward's Avatar
ronward
Redsrover
None - sadly
On a soft top I believe OME HD springs 751 and 762 will give you about 2.5 inches unladen. Check with John at Expedition Exchange for more.
Old April 5th, 2004, 11:41 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
764 front and 781 rear which should put you at 2.5-3" lift.
World traveler
Old April 5th, 2004, 05:06 PM
pangaea's Avatar
pangaea
Nathan Hindman
95 Discovery, D130
David,
Yousef is right, the 764/781 combination is about the tallest that you can get w/o spacers. But you may still need a rear spacer depending on how much gear you carry in the back.
Nathan Hindman
http://www.pangaea-expeditions.com
Old April 5th, 2004, 05:59 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Okay, thanks. So what is the main difference between OME and Rovertym. Which ones are better in your opinions?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 5th, 2004, 06:50 PM
pangaea's Avatar
pangaea
Nathan Hindman
95 Discovery, D130
I'll preface this with the fact that my company sells OME springs, so you might take my information as being biased...
Personally, I think the manufacturing quality which goes into OME springs is much higher than that of the RTE springs. OME shot peens and scrags their springs which goes a long way towards reducing the sagging of the springs.
Most RTE springs that I've seen on the other hand tend to sag quite a bit over time (some over small lengths of time like a couple of months) and I've also seen a few pairs of springs bend or snap as a result of trail usage. This strikes me as very dangerous and I'd be very hesitant to recommend a spring that did that to anyone.
Nathan Hindman
Old April 5th, 2004, 06:52 PM
I think RTE changed thier spring supplier/manufacturer
Old April 5th, 2004, 06:55 PM
pangaea's Avatar
pangaea
Nathan Hindman
95 Discovery, D130
Split up the post to keep it from being an eyesore...
As to the differences, the big difference is that you can get Rover Tym springs in longer free lengths than OME, and with higher lifts than the OME options.
I think that the longest free length on an OME spring is about 17" (OME 764) while I've seen a couple of RTE springs that were 22".
Overall, the RTE springs seem to be better suited to hard core rock crawling due to additional spring lengths and taller lifts, but they don't seem to have nearly the longevity that OME has.
By contrast, the OME springs are shorter and don't (generally) lift your truck as high, but will last alot longer.
Nathan Hindman
Old April 5th, 2004, 08:30 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Had a chance to talk springs with Steve from Rovertym and he has changed the supplier for his springs.
Jimmy Buffett
Old April 5th, 2004, 11:22 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Ok, one more question: How much lift do OME 759 springs provide? Thanks again! Oh, and spring rate if anybody knows would be very helpful.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 5th, 2004, 11:31 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
What's the deal here David? I thought you went with Coil overs all the way around..
World traveler
Old April 6th, 2004, 11:56 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Come on now, we talked about this.. I have coilovers up front but in the rear they are NOT a good idea unless you are:
1. Lifting the vehicle over 7in or so
2. Cutting holes in your floor
3. Running no bed at all
I am not doing any of these and you can get just as much travel out of retained springs, you just need to get the right ones and so right now I am trying different spring and shock combos. I don't really like the springs I have right now all that much. And, I think 1 more inch of lift would be nice for all the junk I put in the back. Soooo, OME 759 lift and spring rate?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 6th, 2004, 01:04 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
How about the rym 3"ers I think they are 285-325 lb/in progressive. Or do you want higher? I think the RYM's flex better then OME.
Legend in My Own Mind.
Old April 6th, 2004, 01:09 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey Randy,
Yeah, I am thinking Rovertym at this point. I "think" the ome 759s that I have now are 260-300lbs and the med Rovertym is 285-325 which sounds pretty good to me especially since I could play around with the valving on the shocks. I still would want to verify with people here the spring rate for sure of the 759's and... Are the 2in springs that rovertym sells really 2.75in of lift and the 3in really 3.75? Randy, you might know this one! Thanks!!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 6th, 2004, 01:19 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I'm not sure since my body is off again and all the weight is not on the truck. But I can tell you that the 3"ers looker really high. Right now I have the 3" in the fron t and the 2" in the rear. THis was due to the TDI being real heavy up front
Old April 6th, 2004, 04:03 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
OME Spring Rates:
http://members.shaw.ca/jbarge/springinfo.html
or
https://www.expeditionexchange.com/ome/indexsprings.htm
Old April 7th, 2004, 01:48 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Hmmm I guess I missed the part about the rear.
World traveler
Old April 7th, 2004, 09:35 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
David, 759s are 260/300 lbs.
John C.
Old April 7th, 2004, 12:01 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks guys! I am going to swap shocks and springs untill I get everything dialed in the way I want it.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
OME HD Springs & OME Nitrocharger Shock Set Steve Friedman For Sale - Parts 1 January 24th, 2008 10:11 PM
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
Actual lift measurement with OME KevinNY Defender Technical Discussions 1 February 2nd, 2006 04:18 PM
OME HD rears or similar 2in rear lift springs evilfij Wanted 1 December 15th, 2004 04:04 AM
OME springs! TwisteD90 Misc. Chit-Chat 5 October 2nd, 2003 06:16 PM
