OME castor correction bushings - Defender Source
Old January 3rd, 2007, 10:11 PM
So what's the verdict? any arguments for or against them? I have a set sitting on my shelf, and wondering if I should install them on my 110. just got my rig, and not clear on whether my lift is stock or not, but seems visually to be riding high. I'm happy enough with the suspension and steering right now, but would be interested in mitigating any driveline stress.
Old January 4th, 2007, 03:26 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Hey Mark,
Incorrect castor won't really cause any additional stress on the driveline. If you do not feel vibrations (from driveshaft angles) and the steering feel is good, you are likely not lifted, or only mildly lifted (or the castor has already been corrected one of a number of ways). If the castor was out significantly, you would know it by the hard pull when you step on the brakes hard, the lack of self centering in the steering, etc.
As for the Castor correcting bushings, the only downside I am aware of is that they limit front axles articulation (not a strong point to begin with) because they reduce the amount of area for flex to take place where the radius arms bolt to the axle housing, because they reduce the amount of bushing material.
~Scott T.
'95 D-90 ST - AA Yellow
Old January 4th, 2007, 04:40 PM
Monkeyboy
Guest
Posts: n/a
And in my experience, they don't last worth a hoot! De-lamination between the rubber and metal bits occurred within six months of installation ... but I'd be happy to sell you the extra set I've got in the bag
Best,
KAA
Old January 4th, 2007, 04:45 PM
Keith, you're a terrible salesman, but thanks for the advise. I'll go with SG3 if I end up lifting.
bushings
OME HD Springs & OME Nitrocharger Shock Set Steve Friedman For Sale - Parts 1 January 24th, 2008 10:11 PM
Lr Hd Vs Ome Hd/md mattarm Defender Technical Discussions 5 September 15th, 2005 09:36 AM
DAP bushings jorge Defender Technical Discussions 5 April 18th, 2005 08:39 PM
Body bushings - poly or factor rubber?? jaherring Defender Technical Discussions 15 February 10th, 2005 06:42 PM
OME 751/764 vs. RTE 2" J4hand Defender Technical Discussions 3 October 25th, 2004 06:18 PM
