OmE 767 coils - Defender Source
Old June 22nd, 2016, 09:39 PM
Naplm00
Matthew
OmE 767 coils
So my terrafirma medium duty fronts aren't going to cut it for my truck:
200tdi
Bull bar
80lb spare on the hood
110 2door
I called lucky 8 and they said that ome 767 front coils were the better uprated coil that won't have the excess rake that the lighter duty tf Springs are exhibiting.
After receiving them they look short... I know the spring rate may be higher but what's the Chance of me. Still sagging?
I have disco isolators for top and. Bottom up front too
Thoughts?
Old June 23rd, 2016, 10:41 AM
I could probably find it somewhere, but do you have the model number and specs of the current springs? Once you have that, carefully measure the static length of the springs in the truck and parked on a flat surface. With those two points of info, we can estimate the weight on the springs and the change in ride height with other springs.
Old June 23rd, 2016, 10:58 AM
Naplm00
Matthew
Current spring info:
Spring rate 230 lbf/in , free length 390mm driver's side, 380mm passenger's side
269.87 mm compressed static height
Old June 23rd, 2016, 11:44 AM
Naplm00
Matthew
OmE spring 767 info
Free height 385 and 375
Spring rate 285lbf/in
Old June 23rd, 2016, 12:07 PM
Okay. 270 mm is around 1" higher than stock, which sounds reasonable for that spring.
Anyway. 230 lb/in, (385-270)=115 mm compression average gives 1041 lbs on each spring.
OME 767 at 285 lb/in gives 1041 lbs / 285 lbs/in = 3.65" compression.... 287 mm static height or 17 mm higher than current and 24% higher spring rate.
Old June 23rd, 2016, 12:25 PM
Naplm00
Matthew
Well I guess I'll put thoes in then. I think if I go any stiffer my kidneys will fall out
Thx for the help
Old June 23rd, 2016, 12:32 PM
Another option.
OME 766. 250 lb/in, 420 mm free length. Will raise 44 mm. Could remove one or two spring packers to drop to a reasonable height. I think they give 10 mm each, so with both out, you will be 24 mm higher than now.
What shocks are you running? I think they can be more important for roughness of the ride,
Old June 23rd, 2016, 12:42 PM
Naplm00
Matthew
Unfortunately in so far upside down due to shipping charges I think I'm just going to stick with these
coil
Weird sparking around coils flynn23 Defender Technical Discussions 8 August 11th, 2008 11:13 AM
OME coils Best4x4 Wanted 2 March 19th, 2008 04:14 PM
Is it normal for Coils to get very hot? btate Defender Technical Discussions 13 August 26th, 2007 11:03 PM
re: What coils do I have?? cneal Defender Technical Discussions 3 November 16th, 2006 01:58 PM
burning up coils tmore Defender Technical Discussions 2 July 23rd, 2005 07:43 PM
