Older non-ST style locks- won't lock - Defender Source
Old March 21st, 2012, 06:41 PM
aosias's Avatar
aosias
Alexandra
1995 D90
My 2nd row door won't lock. Works fine otherwise. I took the door card off to figure it out but I can't really future out what I should adjust. If I hold the key in the lock and turn it the lock will almost engage but not stay. Any ideas of what to start messing with?
Old March 21st, 2012, 07:16 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Alex I have the same exact doors. I am at work but can look at mine when I get home. There are adjustments in the pushrod but if you can't lock, even with the key, I would say the culprit is in the latch itself. Have you tried moving the locking switch on the latch to see if it works? Spray some WD40 of PB Blaster in there to see if it moves easier. Mine is caked with dirt and grease. You may have to have the latch completely rotate on the striker for the lock to work?
MUDSUX
Old March 22nd, 2012, 10:09 AM
aosias's Avatar
aosias
Alexandra
1995 D90
So, it appears the issue is internal to the latch and lock. With the key or the door lock I can't get it to fully engage. The rest of the lock/door seems to be great and there isn't any reason to adjust that from what I can tell.
At this point am I better off replacing the latch or is there a way to take the latch itself apart and adjust it internally?
Old March 23rd, 2012, 06:42 PM
have you considered taking the truck to a locksmith?
Old March 23rd, 2012, 06:54 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Now wouldn't that be logical?
Old March 23rd, 2012, 07:13 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Interesting problem. When I got my 110 pickup, I discovered that I couldn't lock the doors. These are the two piece doors with the recessed, lifting handles. I had a new set of locks intended for my 90, so I installed those. Same problem. Both old and new locks work when the doors are open (or when they aren't installed on the doors), but I haven't been able to make then work when the doors are closed.
John Karlsson
Hope Valley, RI
WTB: G4 roof rack - older style nathanwind Wanted 6 July 21st, 2010 02:28 PM
Gas cap lock & lug nut locks ini88 Defender Technical Discussions 9 August 4th, 2006 01:32 PM
Door Locks Don't Lock ronward Defender Technical Discussions 3 August 27th, 2005 04:57 PM
Power Locks in a ST? mod4b Defender Technical Discussions 9 June 17th, 2005 02:32 PM
diif lock inquiry rover4x4 Defender Technical Discussions 16 February 6th, 2004 07:35 PM
