Old school 110 shock mount help? - Defender Source
Old May 2nd, 2011, 11:41 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
My new rear cross memeber on my 110 has covered the holes for the shock mount, which is the old school type attached behind the rear axle.
I was hoping someone with the same setup could measure the two lines I have roughly draw on the pic, red and yellow, and maybe snap a pickture.
Green arrow points to the front of the truck!
Old May 2nd, 2011, 12:15 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Hey man-
Here ya go. Should be the same as mine.
I have attached all the photos I think you will need.
The lower hole is about 3 1/4" from the spring perch and the top hole is about 7" from the spring perch.
Hope this helps. Did you get my last e-mail by the way about the frame piece? Just making sure it went through. If not I for sure could use it.
Tyler
ID:	38232   Click image for larger version
ID:	38234   Click image for larger version
Old May 2nd, 2011, 01:05 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks, thats exactly what I need!
AS FAR AS THE FRAME PART, I just gotta get one of the kids to cut it out.
Old May 2nd, 2011, 01:21 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Cool. Glad I could help. No worries on part just wanted to make sure you got my message. Whenever you get around to
It is cool.
Old May 2nd, 2011, 01:30 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
You may get the whole chunk of frame.
Doesn't your tranny/tc have a hanger right there?
Old May 2nd, 2011, 03:13 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I will take whatever is easiest. Unless it will cost a fortune to ship. Nope I do not have a hangar there at all.
110, mount
1 or 1.5 inch lower upper shock mount? Santiago Defender Technical Discussions 2 February 8th, 2011 01:57 PM
shock mount redrover Defender Technical Discussions 9 January 19th, 2006 08:22 AM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
