Okay I don't need help...Yet.. - Defender Source
Old April 7th, 2009, 10:42 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Look like something I could get into trouble with?
ID:	18651   Click image for larger version
Keith
Big, Red and ... aaa Red..
Old April 7th, 2009, 10:50 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Yah, man. Get testing. You cannot have too much HP/Torque.
Old April 8th, 2009, 12:10 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Power, Power POWER!
I just want it to flow a little more and do it from the lowest RPM possible.
The Turbo is basically the same size but is a variable vane type. I'm excited to try and get something going with it..
Keith
Old April 8th, 2009, 01:59 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Oh, I'm looking forward to this!
Old April 8th, 2009, 08:23 AM
One of the spacers goes to the downpipe on the manifold, where do the other 2 go? If it were 4 of them I'd think the block side of the manifold but you only show 2.
Old April 8th, 2009, 08:40 AM
I think it is for a 4 cylinder and those are for a custom exhaust manifold.
Old April 8th, 2009, 09:18 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Ding! Ding!Ding! We have a winner!
Keith
Old April 8th, 2009, 09:19 AM
Sorry, the thought of putting a turbo on a 4 cylinder didn't even cross my mind. LOL
Old April 8th, 2009, 09:20 AM
Oxcart13's Avatar
Oxcart13
Mark M
D110
If I know Keith he won't let 'sleeping dogs' lie and will be make a set of adapters for a 5 cylinder too. Just has to find the time.
Old April 8th, 2009, 01:44 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
TD5 is next. We'll see how simple it is and how inexpensive I can get these turbo's, A kit might be in the works.
I've 300TDI Defender in RHD and LHD and TD5 Defender in LHD and a D1 TD5 LHD to make sure of the fit. Might need to borrow a LHD D1 300TDI.. Anyone?
Keith
Old April 8th, 2009, 01:45 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
And a 2.8?
Old April 8th, 2009, 02:51 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
2.8!?!?!?!
that's the turbo system I basically trying to build so it would be nice to have and gawk at.. Yo willing to send yours out? :o
Keith
Old April 8th, 2009, 03:19 PM
are you basically doing this?
http://www.allardturbosport.co.uk/pa..._discovery.asp
because that would be sweet
Old April 8th, 2009, 04:13 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Yup. The goal would be to do it quite a bit cheaper if possible.
My turbo's are a off the shelf model for a Nissan Diesel, If I an do the oil lines and manifold for a reasonable price I could potentially beat the $1950 mark using a new turbo.
For the guys that like to rebuild things like turbos haveing an off the shelf model makes it easier to find a used one and rebuild it for half the price of new or just run it the way you got it like I plan to. This turbo has about 130K km on it and it smooth as silk no reason not to use it other than it's dirty, it actually has less endplay than the one in my truck now.
I'll save the $$ fir new injectors.
Keith
Old April 8th, 2009, 04:34 PM
That's excellent. What do you think of their claim that their system actually improves economy when you aren't flogging it for extra power? I'd be interested in such a system, but I'm unwilling to trade day-to-day economy for extra power which I only need sometimes.
Old April 8th, 2009, 04:41 PM
That is how varible veins work, right?
Old April 8th, 2009, 04:46 PM
My understanding was that variable vanes were mainly to cut down on turbo lag.
Old April 8th, 2009, 05:31 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
and a RHD 200tdi
Old April 8th, 2009, 05:38 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
The idea is that:
It take a lot of speed in the turbo to build pressure in a large turbo but you get lots of flow at higher RPMs so you can pump in a lot of air. You get good high RPM power but turbo lag.
You can speed up a small turbo very quickly to reduce turbo lag but it can be small enough that you do not get the flow at high RPMs hence lower high rpm power.
If you make the turbo bigger and bigger as the RPMs increase you can eleiminate turbo lag and get good high rpm power. The Variable part of these turbos are the vanes on the exhaust side. the vanes are in such a way at low rpm that it take little force to get them going, open like a flower if you will as the boost increases to maximum the actuator starts to modulate the petals of the flower (I know this sounds gay Jimmy) pushing them closer together so the exhaust gases have reduced effect on them, still retaining boost though.
It's not really mor power but better power and reduction of turbo lag I'm after. If you want more power you tune the pump or make the engine bigger. It's possible that with a VGT the options for tuning the pump could be better and more economical since you're not flogging it trying to get it going during lag.
Keith
Old April 8th, 2009, 07:59 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Very Nice Keith. Can't wait...
Legend in My Own Mind.
