oil sump gasket question - Defender Source
Old May 24th, 2012, 06:55 PM
wantone
Rick Thompson
94 ST #1222
hello gentlemen! a quick question concerning sealing up the oil pan. i have the new cork gasket but according to my shop manual, it just mentions putting a 2mm bead of hylosil and then bolting it up and makes no mention of the cork gasket. so should i use just the hylosil or the cork gasket? or use a bead of hylomar and the cork gasket? 3.9L V8 btw.
thanks!
Old May 24th, 2012, 07:06 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
thanks!
Mine leaks too..... been meaning to redo mine.... let me know how it was..... I was planning on using both hylosil & gasket.....
Old May 24th, 2012, 07:48 PM
Grover's Avatar
Grover
I think I am the only one here on this board using the stock cork gasket (everyone else uses right stuff).
I have had great luck with it, no leaks in three years. No hylomar, just a small bead of rtv on the front cover seams and the rear main cap seams.
Cheers...
Old May 25th, 2012, 11:52 AM
wantone
Rick Thompson
94 ST #1222
is 'the right stuff' the hylomar or is the brand 'right stuff' also, just apply a 2-3mm bead and torque it down. if i use the cork (since i already have it) and hylomar do i still torque to the reccomended specs? i just remember cork on valve covers and you used rtv and did not tighten much becasue if you did, the cork would tear.
Old May 25th, 2012, 12:48 PM
Grover's Avatar
Grover
Cork = hand tighten
If tightened too much, the pan bends then leaks happen.
gas
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
4.0 Oil Sump Pan Gasket yes/no Mark McDonough Defender Technical Discussions 2 March 2nd, 2009 03:14 PM
Engine Oil Leak Question ronward Defender Technical Discussions 0 March 22nd, 2005 09:38 AM
