Oil Seperator - 4.0 - Defender Source
Old June 7th, 2012, 07:48 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Oil Seperator - 4.0
I decided to change the oil seperator on my 4.0. However, upon pulling out the spiral piece, the bottom remained at the bottom where the metal tube meets the valve cover. Is there an easy way to get this out? Does the metal tube come out from the top, or does the valve cover have to come off?
Thanks.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old June 9th, 2012, 09:04 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Well, if you are careful you can pull the metal tube without deforming it too badly, remove what is left of the separator, and still be able to reinstall it. It is an interference fit. But I usually find it easier to drill a pilot hole in the plastic for a long screw, put the screw in it and then pull on the screw- usually that pops the broken part of the separator right out.
Old June 10th, 2012, 12:09 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
The screw seems like a good way to go, but plastic shavings slipping into the head are a concern. Have you had issues with that?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old June 18th, 2012, 07:49 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
So, I think I'm going to pull the valve cover to get the broken piece out. It looks 4 bolts and that's it. What size and type are those bolts? Also, running along the top of the valve cover is the fuel lines and heater core hoses. What is the process to insure minimal fluid leakage, particularly fuel, in removing those hoses?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old June 19th, 2012, 08:56 AM
crown14's Avatar
crown14
Verticalscrote
No because the valve cover is off when I do it. But usually the plastic shavings are long and easy to get. You can also use the old grease on the drill bit trick if you would like. Be aware that there is a baffle in the underside of the valve cover that you dont want to drill through. If you want to avoid pulling the cover you can try pulling the tube out.
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
