oil seal - Defender Source
Old April 23rd, 2007, 03:41 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
oil seal
had to replace my stub axle and wheel bearings the weekend. it wasn't till i finished that i realised i put the oil seal on arse about face (back to front). will it last this way or do i need to do it all over again
3rd low and BOOT IT
Old April 23rd, 2007, 03:57 PM
If it leaks grease all over your break pads they will wear out in less then 1000 miles, if you drive it a bunch without grease on the bearings because it all runs out due to a backwards seal your bearing raceway's may spin and screw up your stub. So if your lucky and they hold grease you may be ok for a little while, otherwise worse case you're looking at new break pads, possibly a rotor, new bearings and possibly a new hub.
PS I'm busy tomorrow night,,, but I am pretty sure i am free on the 1st Tuesday next month
Old April 23rd, 2007, 04:30 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
well i know what i'm gonna be doing next saturday. swivels leaking so might as well do that at the same time
3rd low and BOOT IT
93 NAS D-110 Diff oil and Hub Seal Questions AHollander Defender Technical Discussions 16 October 23rd, 2007 02:46 AM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
