Oil questions New D90 - Defender Source
Old October 11th, 2013, 11:24 PM
BRAB
Brandon
200TDI in a RHD 1986 D90
Hi,
So i just bought a 86' defender 90 and was inspecting the under carriage and it seems like there is a slight oil leak. On the outside of the oil sump it seems like there is a lot of dirt and oil built up into a cake like film. I was wondering if this was something to be concerned about or is it just missing a good cleaning? There is a drip or two on the garage floor every few days.
Brandon
Any unrelated advice is appreciated as well!
ID:	81994   Click image for larger version
ID:	81996   Click image for larger version
Old October 11th, 2013, 11:46 PM
Originally Posted by BRAB View Post
Hi,
Brandon
Don't wear spots and stripes, never eat yellow snow and look before you leap.
Oil leaks are just one of the many leaks your defender will exhibit. Water gets in from the sky ... Oil drips out onto the floor. Totally normal.
Old October 12th, 2013, 08:23 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
haha
Old October 12th, 2013, 08:57 AM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
A drip or two every few days??? That's not a leak when it comes to Defenders. She's just marking her territory...
'95 RRC LWB Aspen Silver
'86 110 SW Conniston Green - SOLD
'95 D90 ST Beluga Black - SOLD
'96 D1 SE7 Willow Green - SOLD
Old October 12th, 2013, 11:10 AM
The leak looks like it comes from higher on the engine. What does the top look like? The only way to find and fix leaks is to clean the engine and see where the leak is coming from (unless it is really obvious).
Old October 12th, 2013, 11:18 AM
You sure that is not a diesel leak? It does not look black enough to be engine oil.
Old October 13th, 2013, 10:53 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Clean them off with the pressure washer and please check the levels of t-case, tranny and diffs. I was fairly sure that it was oil leaks, the injection pump didnt leak. It's a 20 year old diesel motor, its gonna leak.
Old October 14th, 2013, 02:02 AM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
Defenders are like radial engine airplanes...If they're not leaking, they're empty
Leaks are a really good thing!
Old October 14th, 2013, 08:43 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Looks like almost every defender I've ever owned. The KEY is to check the fluids. You might want to drain all fluids and replace with what you know are the right fluids and start with a clean slate.
Clay
90, d90
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
93 NAS D-110 Diff oil and Hub Seal Questions AHollander Defender Technical Discussions 16 October 23rd, 2007 02:46 AM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
» Defender Registry
Bess
Yorkie
Watson
80sailor
Add your Defender
