Oil Pressure sensor 2.5TD to 200tdi Conversion - Defender Source
Old October 16th, 2016, 03:58 PM
Richard Ordowich
I replaced my 2.5TD with a Discovery 200Tdi.
The 2.5TD had two sensors on the oil filter assembly but the Discovery 200Tdi only has one.
Is the sensor on the Discovery 200Tdi the oil temperature sensor or the pressure sensor?
Which wire should be connected the this sensor? I have one wire that is White with a Brown tracer and the other one is Red.
Is there no oil pressure sensor on the Discovery 200Tdi?
"Slow down and smell the diesel"
Old October 16th, 2016, 04:34 PM
1960 109, w/200TDI
The oil pressure switch should be on the oil filter housing and it will have a white/brown wire from it to the gauge.
Retroanaconda.com for parts info
Solid red wires are used in the lighting circuits.
1960 109
1960 88 Ignotus
200tdi, conversion, sensor, tdi
2.5TD Turbo / 2.5TD Air Box and Bracket LakeLBJ For Sale - Parts 1 May 20th, 2016 09:05 PM
2.5TD Conversion to Discovery 200tdi Throttle cable assembly richord Defender Technical Discussions 1 April 10th, 2016 04:19 PM
2.5na oil pressure sensor PabloCocito Defender Technical Discussions 6 February 4th, 2015 06:29 PM
Oil Leaks and Pressure build up on 19J 2.5TD Engine richord Defender Technical Discussions 9 August 13th, 2014 05:16 PM
Defender 200tdi...oil pressure sensor and diff lock switch sonoronos Defender Technical Discussions 4 July 28th, 2011 04:10 PM
