Oil Pressure Sender Thread Size 4.0V8 - Defender Source
Old January 8th, 2016, 10:18 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
I'm trying to test my oil pressure with a Pittsburgh Oil Pressure Gauge from Harbor Freight. The kit I bought including 12 adapters but none of them fit, two are close but are really too big. One of the fittings is a 1/8"-28 BSPT Male fitting, none of these work. I've tried finding an adapter at a hydraulic/hosemaker shops who assured me they had all of the British sized fittings. Still nothing will screw into the oil pressure sender port on the timing cover. Has anyone had any success finding a fitting to allow a capillary tube to be attached to test the oil pressure? This fitting is not metric, BSPT or NTP.
ID:	138888   Click image for larger version
ID:	138890   Click image for larger version
Old January 8th, 2016, 11:26 PM
Should be M10x1.0 AFAIK.
Old January 8th, 2016, 11:28 PM
Or might be 1/2" UNF, which means a -5 ORB fitting.
Old January 8th, 2016, 11:31 PM
Yes, STC4104 is 1/2" UNF, so you want -5 ORB. Your hydraulic shop guys are not too swift if they could not measure the thread size. Common, normal hydraulic fitting.
Old January 9th, 2016, 12:01 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Thanks for the info!
v8
Tdi VDO oil pressure sender help Uncle Douglas Defender Technical Discussions 15 August 1st, 2014 12:08 PM
Confused about oil pressure sender. VDO replacement sundogcwolfe Defender Technical Discussions 3 May 20th, 2010 06:24 PM
Has any one installed a VDO oil pressure sender on the '97 - 4.0? LenB Defender Technical Discussions 8 March 29th, 2010 01:30 PM
oil pressure sender tomaco1 Defender Technical Discussions 2 October 7th, 2009 09:00 AM
Part # for Oil Pressure Sender 61rover Defender Technical Discussions 2 June 8th, 2009 05:29 PM
