oil pressure sender parts for 300TDi - Defender Source
Old July 19th, 2011, 02:37 PM
TS888's Avatar
TS888
Tony Sims
1984 110
A point of reference -- the parts for the oil pressure sender (for the factory gauge) from a 200TDi will work on a 300TDi. The only modification required is to trim about 3mm off the threaded part of the extension, P/N ETC4033, so that it does not bottom in the oil cooler housing.
The part numbers required are:
ETC4033 extension mount (pic below)
ETC4034 banjo fitting (pic below)
PRC4043 pressure sender
You also need 4 copper or aluminum sealing washers.
To install -- remove the oil warning light sender from the oil filter housing. Install ETC4033 and ETC4034, providing two install ports for senders. Install your oil light sender on one port, and the oil pressure gauge sender to the other port. Connect wires, job done.
Tony
1984 110 "Smokey" (sold)
Old July 19th, 2011, 06:48 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Thanks. I've been wondering about how to do that.
John Karlsson
Hope Valley, RI
300tdi, part, parts, tdi
Has any one installed a VDO oil pressure sender on the '97 - 4.0? LenB Defender Technical Discussions 8 March 29th, 2010 01:30 PM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
