Oil Pressure Gauge install for GEMS - Defender Source
Old January 8th, 2015, 09:23 AM
MotoMando
Armando Centeno
1997 Defender 90 SW
I want to add an oil pressure gauge on my GEMS engine. Should I use an oil filter sandwich plate or tap into the low oil pressure light sender?
Old January 8th, 2015, 09:46 AM
the rover shop
shayne young
I use at T junction if you want to keep the oil warning light..otherwise install a sender instead of a switch and just go by the guage..they make ones that have a warning buzzer at below 7 psi also..
Old January 8th, 2015, 01:08 PM
psykokid
Jake
1997 Disco
What's the thread pitch for the oil pressure sender on the GEMS motor trucks? I've got an M10x1 VDO sender with the warning terminal that would work great, just need to find the right adapter bush, if necessary, and get it installed.
sender P/N for factory oil pressure gauge 300TDi TS888 Defender Technical Discussions 4 May 28th, 2011 06:56 AM
110 Oil Pressure Gauge bjf Defender Technical Discussions 2 June 26th, 2009 12:34 AM
Oil pressure gauge mpsteil Defender Technical Discussions 3 September 14th, 2007 01:20 PM
Oil Pressure Gauge texasdefender110 Wanted 0 May 1st, 2007 04:54 PM
Oil pressure gauge/voltmeter from a D110 w/3.9L Grover Wanted 0 January 18th, 2007 01:12 PM
