Oil pressure gauge - Defender Source
Old September 13th, 2007, 04:25 PM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
Oil pressure gauge
The oil pressure gauge on my 110 in reading just under 60psi which is almost max. I know there is no way I have that much oil pressure and the truck has 140k on it. I unplugged the sending unit and the gauge went back to zero(it also goes to zero when the motor is off). I am guessing it is the sending unit but at $125.00 I want to be sure before I order it.
Thanks, Mike
Old September 13th, 2007, 05:18 PM
Grover's Avatar
Grover
Thumbs up
Check out my VDO oil pressure install in the Small Projects section. A new VDO gage and sender will cost less than $125, plus it reads actual pressure...
http://www.defendersource.com/forum/...08&postcount=1
Cheers...
Old September 14th, 2007, 10:54 AM
mpsteil
Michael Steil
Thanks, Mike. I like your setup but I am going to keep the stock gauge. I am hoping somone here has a troubleshootign plan for the sender.
Old September 14th, 2007, 01:20 PM
Chaucer
Will
93 110 | 97 90
How does one determine if the problem is with the sender vs. the gauge? Isn't there some sort of resistance you can measure with an ohm meter? Then, I guess the next step is to know what the proper measurements are. Otherwise it's 50/50 to buy a brand new part and swap it out on a hunch.
110 Oil Pressure Gauge bjf Defender Technical Discussions 2 June 26th, 2009 12:34 AM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
