Oil pressure gage - Defender Source
Old February 17th, 2004, 08:35 PM
Oil pressure gage
Have many people here installed one? How hard are they to install?
Old February 18th, 2004, 12:36 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Phillip,
I JUST completed this installation. It is rather simple, or so it was on my 95 3.9L. On the oil pump there are (at least) two 1/2-20 threaded ports. One of the ports has the OEM pressure switch for the idiot light. Up a little ways (inch or so) and around back the second port has a 1/2-20 plug. I removed this plug, machined an adapter (more in a second), and then was able to install the pressure gauge sender. Pulled a new wire back to the cabin, pulled power wire from switched source behind the dash, tapped into the light circuit so the new gauge would illuminate, and that was about it. Now the more difficult part: making the adapter. I used stainless 3/4" hex and machined it down on one end to 1/2-20 threads and then cut a hole all the way through and tapped the through hole to 1/8NPT for the new sender. Worked like a champ. I drew it up in Autodesk Inventor if you would liek the drawing I can send it to you, or anyone for that matter. While I was in there, I fabricated stainelss steep hard-pipe oil cooler lines and used a -8AN fitting with stainless braided hose. The only remaining part is the large Banjo at the pump I have not replicated (yet). I sent Chris V a not asking if he wanted it written up, cause I can write the whole thing into a tech article. Let me knwo if I can help.
JBR
Pain is weakness leaving the body
Old November 30th, 2004, 08:24 PM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
Does anyone know if the oil pump on a 97 4.0L D-90 has the same extra threaded ports? (It may be I just wasn't looking in the right place, but I don't believe mine does.) That would definitely solve a problem which has vexed me for months: rigging up a t-adapter to run both the OEM idiot-light pressure switch and a sender for a mechanical guage through the existing port.
First problem: the space available there is very limited, so threading together the adapter is not easy. Second problem: every adapter configuration I've come up with leaks (more than the rest of the engine).
Any thoughts?
Old November 30th, 2004, 09:04 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
You can take an old pressure sender, break out the top plastic part, drill it out and tap it, slam dunk.
Old November 30th, 2004, 09:44 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Neo. Did you replace the entire oil cooler line with a hardline, from the pump to the cooler? That gives me a bit of cause for concern. The engine will flex a bit in the engine mounts by design. If you don't have any flexible portion in the cooling lines, eventually something might crack and fail. Just from the "weakest link" standpoint, I'd bet on the fittings going into the cooler would go first. I may be totally wrong, but I tend to design from a worst case viewpoint.
Trevor. Have you possibly considered a T-fitting up where the oil lines go into the cooler? I am thinking about doing that to add a small mechanical gauge for when I am tinkering under the hood. Got that idea from some muscle-car friends of mine. A lot of them had temperature and pressure gauges under the hood so they could monitor things while working on the engine, and they wouldn't have to run to under the dashboard to check things.
-Hans
Whoops, disregard. I didn't see the "flexible braided lines" part in there, my bad. You've already got it set-up just the way it should be. I really have to start reading posts more slowly.
Hey, what size are the fittings on the oil cooler and pump anyways? I'm due to replace mine, and was about to do the same thing. (you'd probably make a few bucks selling some bolt-in replacements for the stock lines)
-Hans
My oil line fix
My 100k stopped odometer fix
Oil Pressure 'sticky' jaherring Defender Technical Discussions 5 July 3rd, 2007 11:59 AM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
