Oil Pressure? - Defender Source
Old February 14th, 2013, 09:29 AM
Oil Pressure?
The transport company just delivered the green beast to my house this morning. I cranked it up to drive it into the garage and I noticed that the oil pressure gauge indicated zero. Its one of four things:
Oil pump
Sending unit
Gauge
Wiring
Is there any way to tell if oil is actually flowing without damaging something?
Engine is a 2.5 liter NA diesel
Old February 14th, 2013, 09:37 AM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
If that is an exMOD they typically aren't equipped with an oil pressure gauge. Instead it is an idiot light connected to a switch that is screwed into the oil filter adapter.
Make sure you are looking at an oil pressure gauge and not an oil temperature gauge, which IS often found on exMOD rigs, particularly FFR units.
Old February 14th, 2013, 09:41 AM
Thanks meatblanket! Thats what I get for looking at it in total darkness. They delivered it well before sun up this morning. Heart attack averted!
Old February 14th, 2013, 09:47 AM
meatblanket
Mike Simpson
If there is an owners manual for these, I haven't seen one.
Congrats on the purchase, you'll have a lot of fun with it!
Old March 1st, 2013, 07:07 PM
jafir's Avatar
jafir
Jafir Elkurd
I've got a very similar 90. Where is this oil pressure light, in relation to the other warning lights? I don't see my warning light come on when I turn the key on, so I'm wondering if I don't have a bulb there or maybe the switch is bad.
Old March 1st, 2013, 07:25 PM
jafir's Avatar
jafir
Jafir Elkurd
Perfect! Thanks. I pulled that panel out and swapped the battery/alternator light with the oil light, and the battery light still works and the oil light still doesn't, so I guess I have a little more troubleshooting to do.
I think I did just discover that my 90 might have been used in the desert or something because there is a lot of dust inside the dash. Or maybe that's normal.
Old March 1st, 2013, 10:00 PM
I washed about 20 pounds of Iraq out of my truck and chassis. All the switches were covered with grit too.
Mystik 15w50 and a flickering oil pressure light Naplm00 Defender Technical Discussions 3 May 1st, 2011 12:49 AM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
