Oil Pan Re-seal- Hylomar or Right Stuff? - Defender Source
Old September 30th, 2008, 12:59 PM
Grover's Avatar
Grover
Question Oil Pan Re-seal- Hylomar or Right Stuff?
Seems everyone touts "Right-Stuff" for sealing the oil pan. I have a tube of Hylomar from RN I've used on water pumps. Anyone use Hylomar as a sealant for the oil pan? Also, do I have to worry about losing prime when the oil pan is off?
Cheers...
Old September 30th, 2008, 02:27 PM
Hylomar will not work in that application.
Ron
Old September 30th, 2008, 02:42 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Use Right Stuff it will work great in that application. If you leave the filter in place you should not have any prime problems.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old September 30th, 2008, 06:07 PM
Grover's Avatar
Grover
Thumbs up
Right Stuff it is! I ordered the Hylomar and a cork oil pan gasket about 2 years ago from RN. One would think they would advise using Right Stuff without the gasket.
It's good to know that I will not lose prime with the oil pan dropped. I figure the project taking a couple of hours.
Any advice on pulling the pan any from the block? I'm think on using a plastic puddy knife or something that will not gouge the block or pan...
Thanks for the input!
Cheers...
Old September 30th, 2008, 06:28 PM
http://www.defendersource.com/tech/o...placement.html
Old September 30th, 2008, 10:02 PM
Grover's Avatar
Grover
Originally Posted by rover4x4
Thanks. I reviewed this write-up. I see he used a gasket scraper to remove the old sealant. I was just questioning how difficult it will be to break the seal between the block and the oil-pan.
Cheers...
Old October 1st, 2008, 01:50 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Flat head screw driver.
Old October 1st, 2008, 02:01 PM
" ordered the Hylomar and a cork oil pan gasket about 2 years ago from RN."
This is what application hylomar is for. I prefer it to the right stuff, but the cork gaskets are $$ and do not last forever.
ht
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
» Defender Registry
Blanca
roverguy2
Rangie
pl626
Add your Defender
