Oil Pan Question - Defender Source
Old March 2nd, 2011, 04:42 PM
usadventureracing's Avatar
usadventureracing
Brett
110
Oil Pan Question
How can I find out if I have the original oil pan? Is there an "easy" way to do this?
1983 ROW D110
1970 Series III (Parting out)
Old March 2nd, 2011, 07:23 PM
Post a picture of it and someone should be able to identify it... But, why does it matter?
Old March 2nd, 2011, 07:51 PM
usadventureracing
Brett
110
Because I cannot get a reading on my dipstick until after 8.5 quarts of oil. I have the correct dipstick, but now think maybe I have a larger oil pan.
1983 ROW D110
Old March 2nd, 2011, 08:42 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
what's the engine?
Old March 2nd, 2011, 11:06 PM
http://www.defendersource.com/forum/...ad.php?t=29125
Originally Posted by pendy
I'm here for the D's
Old March 3rd, 2011, 01:26 AM
Naplm00
Matthew
maybe the wrong dipstick?
Old March 3rd, 2011, 03:49 AM
TS888's Avatar
TS888
Tony Sims
1984 110
I've never heard of a larger capacity oil pan for the V8, but that doesn't mean they aren't out there. Looking at the other thread, you've confirmed the dipstick is correct -- what about the tube?
Tony
1984 110 "Smokey" (sold)
Old March 3rd, 2011, 07:44 AM
Good point, but possibly tricky for him to determine without pulling the pan. I have a tube/stick from a 94 D90 (3.9L) that I could measure.
Heck, maybe one of the pro's can confirm this, but I'm willing to bet a pan and tube/dipstick from 3.9L would fit on your block fine and be a proper "pair". If this is the case and you want them, let me know.
Old March 3rd, 2011, 12:33 PM
usadventureracing
Brett
110
I would be interested if this would work on my truck, please let me know what you are asking for it.
I will be draining the oil on Friday and will post picks of my oil pan to see if anyone could tell if it is original or aftermarket
1983 ROW D110
Old March 3rd, 2011, 05:54 PM
I don't need anything for it but I don't think I'll have time to pull it until next week. The dipstick is accessible so we can can compare measurements there I guess.
Can anyone confirm that the sump/dipstick tube/dipstick setup from a 3.9L V8 will fit a 3.5L V8?
charles
Old March 3rd, 2011, 06:42 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
They are the same. All the 3.5 and 3.9's were the same. You can even use a pan,stick, and tube off of any year D1 even the 4.0's. The GEMS RR's and Bosch stuff is different. Don't check the oil with the engine running and you won't get a reading of 8.5 qts.
Old March 3rd, 2011, 11:16 PM
Brett, if it helps, here are the dimension on the 3.9 dipstick
Stick- from top of the "bell" to the tip is 22 1/4"
Stick- from bottom of the "bell" to the tip is 21 5/8"
Tube - total length 17 3/16"
Tube - top to seat where meets the block 8"
Tube - seat to bottom 9 1/4"
When the dipstick is fully inserted, 5" protrude from the tube.
hth
charles
Old March 4th, 2011, 04:55 PM
usadventureracing
Brett
110
Issue solved, after looking at cqalpin's measurements I realized my tube was not seated all the way. I seated the tube and changed oil and added 6 quarts and she is full. Thank you everyone for all your help.
1983 ROW D110
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
