Oil Pan pick up install - Defender Source
Old April 25th, 2007, 02:11 PM
TND90's Avatar
TND90
Keith Allen
94 d90 ST
I am going to be putting my oil pan back on this weekend and was wondering if there were any special steps concerning the oil pick up line. I have cleaned everything up and the screen is clean on the oil pick up. Any other steps or do I just put it back together like I found it?
Old April 25th, 2007, 02:13 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would use a lock-tight substance on the two bolts...
Old April 26th, 2007, 01:21 AM
TND90's Avatar
TND90
Keith Allen
94 d90 ST
Thanks Chris, any priming or anything?
Old April 26th, 2007, 06:56 AM
robisonservice
John Robison
2008 Supercharged Range Rover
With respect to priming - if you pack the gears with vaseline or wheel bearing grease it will prime a lot quicker. And don't use any kind of silicome sealant when fitting up the pickup as I've seen that sucked into the pumps where it caused trouble.
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
