oil pan gasket - Defender Source
Old January 22nd, 2008, 12:21 AM
justinaldi
justin aldi
none
oil pan gasket
any tips/hints for replacing the oil pan gasket. It is a stock 3.9 in my 95.
Justin
Old January 22nd, 2008, 12:54 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
DON'T USE A GASKET. Sure, you can if you want, but let me repeat: DON'T USE A GASKET. Use RightStuff--you can get it at most any auto store. Clean both surfaces really good, then run a bead of rightstuff all the way around the oil pan, install. Easy. Tons of us do it this way and will never bother with a gasket there again.
Old January 22nd, 2008, 12:57 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, I don't know a single LR tech that uses anything else either!
Old January 22nd, 2008, 02:54 AM
JSQ's Avatar
JSQ
Jack Quinlan
Use rightstuff.
...but not too much.
Old January 22nd, 2008, 06:55 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Gasket
...I know a guy who just installed an oil pan gasket in his D-90...
Semper Fi!
gas
4.0 Oil Sump Pan Gasket yes/no Mark McDonough Defender Technical Discussions 2 March 2nd, 2009 03:14 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
