Oil on Floor mat - Defender Source
Old April 15th, 2006, 10:10 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Question Oil on Floor mat
I'm noticing a bit of oil on my floor mat, the oil spot is under my clutch & it looks as if it's pripping from my clutch.
Could it be my "Clutch Master Cylinder" ?, I checked my level of oil & it appears to be fine ?
Just looking for any ideas on what it maybe before getting it checked out.
Weldon
Old April 15th, 2006, 10:32 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
That's what mine was.
"It's not a Jeep"
Old April 15th, 2006, 10:35 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Yep, the dreaded clutch master cylinder.
Old April 15th, 2006, 11:27 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
How difficult is this to replace yourself ?
Weldon
Old April 15th, 2006, 12:16 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Access is very, very poor. Not 'Hard' but more hard to get at. Some folks have mentioned removing the hood helps.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 15th, 2006, 02:45 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Seems like I remember quite a bit of info if you search through the forum.
When you or someone else pulls the master cylinder see if the bottom of the cylinder has some dissolved black stuff in it, like rubber seals.
Rovers North has a tech tip that says anything other than Lucas or Castrol LMA fluids may cause seal failure. I think this is why mine went bad.
I rebuilt mine instead of replacing it. It's easy once you have the master cylinder out. If the walls of the cylinder aren't scored then new seals is all it should need.
Old April 15th, 2006, 07:42 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Its not a hard job. I cant remember if you can remove the pedel tower without removing the brake tower first.. I would try to just remove the tower though. Also, while you have the system drained, get a new rubber hose for the bottom and a rebuild kit for the slave. Do it all at once and you won't be sorry in the end.
Legend in My Own Mind.
Old April 16th, 2006, 11:04 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Thanks for the replies !
I've always used Catrol fliuds for clutch / brake & I agree on changing master & slave together...
After inspecting a bit further I'm still a little puzzled, around the clutch master cylinder it's very clean & the level is very good, my next step is to inspect aroud the clutch ?
& yes I can see why it's going to be a pain in the A@% to remove & install !
Weldon
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
