Oil (maybe) timing case and injection pump - Defender Source
Old February 3rd, 2016, 02:07 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I will preface this by saying that I don't think I have a real issue here, however I thought I would just make 100% sure I'm not missing something.
So I was replacing my timing belt today on the 300tdi and I noticed that there's some fluid that looks oily seeping in around the three bolts that secure the injection pump to the timing case.
It's not a huge amount, and it looks like it has been in there some time, as there is old looking residue on wall of the case below the pump. There is also a bit of discoloration on the timing cover in the corresponding area.
I can't possibly see were this fluid would be coming from and it's completely dry on the outside of the timing case around the bolts.
Has anyone seen this before? I don't want to miss something before I simply clean it up and bolt everything back together.
**note the really black stuff on the inside of the case is timing belt fuzz**
Photos below.
ID:	141238   Click image for larger version
ID:	141240   Click image for larger version
ID:	141242   Click image for larger version
Old February 3rd, 2016, 08:00 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Should be a seal on the shaft behind the pulley. Could have leaked at one time but if the leak doesn't look active then????
Land Rover 110
Old February 3rd, 2016, 08:16 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
It really looks like the fluid is exclusively coming through the threads, I can't see any oil near the seal area. Could be something old I guess, as you suggest. I'm speculating that either the bolts were lubed up when they were last installed or during an engine cleaning fluid was pushed through the threads... I just can't figure what else would cause it.
95 4.2 front timing cover & oil pump cover psykokid Wanted 4 August 14th, 2015 06:16 PM
TDI Injection Pump Timing BRAB Defender Technical Discussions 29 April 24th, 2015 06:19 AM
2.5 Na desiel Injection pump removal and refit Beaver87 Defender Technical Discussions 7 December 17th, 2013 07:22 PM
Engine won't start. Timing chain maybe? ini88 Defender Technical Discussions 12 December 30th, 2010 10:56 PM
harness on 300 tdi injection pump Abrooks Defender Technical Discussions 5 February 22nd, 2009 12:27 PM
