Oil Light When downhill braking - Defender Source
Old September 19th, 2006, 10:55 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Ok, here's the problem. When I brake hard on a downhill my oil light is coming on and it sounds like one of the lifters is sticking. Typically I have found this to go away once the engine rev's a little bit. No I don't have a pointy head, I found this out on the trail and had no choice but to rev the engine to get up some of the other hills. Anyway does anyone have any ideas why this might be happening.
Old September 19th, 2006, 11:13 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Sounds to me like your oil level is low, or it's a really steep hill, and the pickup tube is getting exposed. The pickup tube is at the rear of the oil pan, and nosing over too much and hitting the brake too hard can easily slosh all the oil to the front of the pan.
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 19th, 2006, 11:16 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
No, thats not it. The oil level is full and this happens on your typical city street.
I just went out and tried it and light has gone out and I drove it around the block and the lifter noise went away. If I jamb on the brakes hard going down hill it will come back.
Old September 20th, 2006, 01:34 AM
Hans's Avatar
Hans
Hans Haase
hmmmm.... I wonder if maybe the pickup tube is cracked? The light and the lifter tap mean it's a definite drop in pressure, not a false symptom. How many miles on the engine?
-Hans
My oil line fix
Old September 20th, 2006, 06:04 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
either the oil pick up tube is blocked or cracked and or the oil pump is on its last legs. If as you say you can get this to occur on the flat under braking then the oil pump may be the culprit
Old September 20th, 2006, 08:38 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I had the same thing happen on 2 different rovers.
In both cases the bolts that hold the pickup tube in place came loose, hopefully yours is as simple as that.
Old September 20th, 2006, 10:04 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Gentleman Thanks,
It looks like I will be pulling the pan and checking the tube.
ht
The dreaded 30 second blinking oil light at startup - anyone have a fix for this? solihul Defender Technical Discussions 10 December 2nd, 2004 01:39 PM
Oil Light Flickering/Oil Pump Glenn_Guinto Defender Technical Discussions 13 October 27th, 2004 08:27 AM
D-110 Oil Light Flickering?? sharknet Defender Technical Discussions 12 May 27th, 2004 10:06 AM
