oil light on 4.0 V8 - Defender Source
Old November 15th, 2008, 04:22 PM
rovernutzz
duncan goodchild
16x defenders...... so too many !
oil light on 4.0 V8
so i have a strange one with my 4.0 V8. the oil light comes on above 1500 rpm and is off below it. i have looked through the forums and can only find details on the usual, light coming on at idle or all the time.
anyone got any ideas ? i checked the oil and it is at the full mark on the dipstick.
i am more of a diesel nut so dont often have a gas engine in one of my rovers. this engine will be coming out early next year for a diesel conversion but i would like it to last me till then atleast......
Old November 15th, 2008, 05:29 PM
a clogged strainer screen on the pickup for the oil pump ?
Old November 15th, 2008, 06:39 PM
rovernutzz
duncan goodchild
Mmm that would bbe the first port of call on things to try i suppose....... i have scoured teh forums and no one else seems to have described these symptoms.... i will try that tomorrow or monday and let you know doug.
do you know of a vdo gauge that is easy to hook up and make sure i see what i am actually getting in pressure ?
ps, just read through your left hand drive conversion write up...... great job there :O)
Old November 16th, 2008, 11:56 AM
weissbrewer's Avatar
weissbrewer
Stephen Johnson
94 AA D90
Duncan, thisa happened on my 3.9 and Doug is on the money. I had a clogged pick up screen.
Cheers
Steve
94 AA Yellow D 90 ST/ disco 200TDI installed!Luvin 300+ miles per tank
1982 Series 3 HCPU gone but missed
Old November 16th, 2008, 12:59 PM
agavelvr
Guest
Posts: n/a
What about the alternator?
Take my advice with a grain of salt, as I know very little.
I've been trying to solve one of my electrical mysteries this weekend and read that the oil light activates when you turn the key. It turns off once the alternator starts outputing power = to the battery. I wonder if the oil light would come on if your alternator's output diminished at higher RPMS for some reason.
Something to check out perhaps.
Good luck,
Jeff
Old November 17th, 2008, 01:20 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
hi duncan, i had a similar fault on my 3.5, turned out the relief valve was sticking, i swapped out the cap type valve for a tadpole type relief valve and all was well.
now I fit uprated pr spring and tadpole valves as a mater of course when rebuilding.
could also be clogged strainer, crap oil, or oil presure switch.
Old November 17th, 2008, 03:14 PM
rovernutzz
duncan goodchild
Old November 18th, 2008, 06:56 PM
rovernutzz
duncan goodchild
so there was some gunk in teh sump when i took it off today, cleaned everything out including the strainer screen. put it all back together to find it made no difference.... infact it seems the light comes on MORE. what is next on the list ?
Old November 18th, 2008, 07:24 PM
Did you verify the strainer was bolted on tightly? I once removed my oil pan to find the strainer was loose!
Old November 18th, 2008, 09:19 PM
Bad sensor. There was a recall for the discos.
Old November 19th, 2008, 01:28 AM
rovernutzz
duncan goodchild
yes charles........ i took it off..... was surprised at how easy the bolts came undone but i dont think it was that as i put it back on tight and its doing it still...... sensor does seem the next call then it is going to be taking the oil pump off if that doesnt do it....
Old November 20th, 2008, 08:55 PM
rovernutzz
duncan goodchild
ok folks.... for those interested....... after dropping the oil pan, cleaning everything out and still getting the same problem it turned out to be that the wrong oil filter had been fitted and it was restricting flow ! yes.... that simple. all good again with the 4.0 :O) thanks to don at rovertech in vancouver for his help and troubleshooting..........
ht, v8
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
Oil Light Flickering/Oil Pump Glenn_Guinto Defender Technical Discussions 13 October 27th, 2004 08:27 AM
D-110 Oil Light Flickering?? sharknet Defender Technical Discussions 12 May 27th, 2004 10:06 AM
