Oil light flickers during left turn - Defender Source
Old June 24th, 2013, 07:21 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
So I'm stumped trying to figure out what might cause this by external means. I wanted to ask if anyone else has experienced this before I drop the pan and start poking around.
This just started the other day after about 80 miles of highway driving. I currently have Rotella T 10w-40 in the truck (3.9).
Obviously this isn't just related to the wheel being turned. It happens whilst driving and turning left as well as when stationary and parked leaning towards the passenger side.
I have no other flickering of the light (at idle for example). Yes the oil level is fine. No I do not have an oil pressure gauge - just the idiot light.
Any ideas about what I might run into?
Old June 24th, 2013, 07:26 PM
Oil pick up partially blocked by crap, usually bits of right stuff RTV from the pan.
Old June 24th, 2013, 07:29 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Best case faulty sensor...worse case pump. There's not a whole lot of figuring out on this one...IMO.
Old June 24th, 2013, 07:34 PM
cellulararrest
Chris Snyder
mmmkay. I'm fairly certain the sensor is good. I actually replaced it 4 or 5 years ago.
The leaning/left turn thing is what was throwing me as far as why it's happening.
Old June 24th, 2013, 07:45 PM
Time to drop the oil pan, inspect/clean/replace the pick up and clean the oil pan.
And while you are at it, add an oil pressure gauge.
Old June 24th, 2013, 08:19 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Oil pressure gauge...
Before pulling the pan, follow this good suggestion to hook up a calibrated oil pressure gauge you know is accurate on a temporary basis just to verify that the idiot light is functioning properly.
This will assist your decision making before you remove the oil pan or decide what your next course of action is.
RDavisinVA
Old June 24th, 2013, 08:26 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Could also be loose bolts on the oil pick up--this may account for the loss of suction when the truck is off camber.
Old June 24th, 2013, 11:46 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I have had this happen to 2 rovers and know of several others that have had this happen as well.
Old June 25th, 2013, 08:11 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Check for a loose connection at the sensor
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old June 25th, 2013, 08:18 AM
cellulararrest
Chris Snyder
I like your theory.
That was the first thing I checked. It's definitely related to the truck being off-camber though.
Thanks for the suggestions. Looks like the pan is coming off this week. I'll let you know what happens.
Old July 7th, 2013, 02:36 PM
cellulararrest
Chris Snyder
Well the oil pan has been dropped and cleaned (it was pretty clean to start with). I also took the oil pickup off and cleaned it out (the bolts were tight). The screen itself looked fine. I also did the filling it with gas test to check the entire assembly for leaks (it passed).
After reassembly, it is still showing the same behavior. Of course it makes sense since I didn't really find anything amiss.
I think my next step is checking everything electrical (including the sender) so I can truely rule it out. Then fit a pressure gauge so I can get an actual idea of what's going on.
Old July 7th, 2013, 03:49 PM
Well, that is both good and bad news. If swapping the sensor and checking the grounds does not work, I would put on oil pump rebuild kit in it if the pressure is actually low.
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
Left side light bezel. rd10014 Wanted 2 May 16th, 2012 08:51 AM
Relocating bumper turn signals to the upper light housing paulb Smaller Projects 1 March 17th, 2007 10:50 AM
Oil Light When downhill braking Baldewin Defender Technical Discussions 6 September 20th, 2006 10:04 AM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
