Oil Light - Defender Source
Old August 29th, 2005, 03:00 PM
milli's Avatar
milli
Michael D. Milliken
9590SW
Oil Light
The truck is running rough and the clutch is slipping. Soon for sale maybe! (not).
The thing that worries me is when the oil light comes on. It always happens at a stop after the truck is warm and begins flickering when the RPMs drop to about 700 (where the truck normally idles). There is also a smell of oil around. Any suggestions?
Old August 29th, 2005, 06:26 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
How many miles on the oil? Usually mine starts to do that when the oil needs changin.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 29th, 2005, 11:07 PM
What oil are you running, sometimes that can be fixed by running thicker oil
Old August 30th, 2005, 08:16 AM
milli's Avatar
milli
Michael D. Milliken
9590SW
Valvoline 10 30. It is pretty hot here in Florida. I think I may have over filled it by a quart. It is about 1/4" over. Could that be it? I cannot see any new leaks.
PS
Don't want to beat a dead horse here, but can I do this to my truck even though it is a '95?
http://www.siegecraft.us/mocal.htm
Old August 30th, 2005, 09:14 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The over fill is not your problem--it would not cause the low oil pressure light from coming on. It is not too uncommon that at low idle some people have it come on or flicker, but it is nothing to fully ignore in my opinion either. There are many things that cause it, from too thin oil to worn pump, but the worn pump is pretty rare. Others with the crank fed pump should chime in, since my experience is with distributor based--but it is not the overfill.
Old August 30th, 2005, 09:21 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
i put in 15-30 which stopped the oil light comming on
3rd low and BOOT IT
Old August 30th, 2005, 01:20 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Mine did the same thing installed a new sender & presto! the part is cheaper than a oil change
Old August 30th, 2005, 01:22 PM
milli's Avatar
milli
Michael D. Milliken
9590SW
what's that?
Old August 30th, 2005, 01:37 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
i will post a pic later
The white outa focus thing
Name:	110 resto 014.jpg
Old August 30th, 2005, 03:08 PM
artm
Arthur Maravelis
97 SW
You need a pressure gauge anyways so why not fit a good one and start there? If the pressure is indeed low then you can consider oil changes.
My '93 LWB did the same thing with 10W30 and a switch to 10W40 cured it. You need the thicker viscosity while hot - I don't see how going to 15W30 would help. I'm sure it did for Jimmy but...
Old August 30th, 2005, 05:32 PM
milli's Avatar
milli
Michael D. Milliken
9590SW
Well my mistake, it's 5w30. Is that a little light? I should have listened and used all climate 20w50 like my lr friend told me! I'll switch it up I guess.
When I also told him the clutch was slipping and I thought I needed to replace it (110K) he laughed and said he has never had to replace a clutch on a defender because it is just too heavy. He had me do this little test to see....
Release the bleeder nipple on the slave cylinder
Put it in first (no clutch)
Turn ignition
Go
Shift to second (no clutch)
Floor it
= if there is no slippage, the clutch only needs adjusted.
I am not sure how this makes sense, but it didn't slip as far as I could tell and that's good.
He says I should have free play in the clutch. Like the first inch of movement should have no pressure (mine does). Hmm. Any thoughts? Thanks!
ht
The dreaded 30 second blinking oil light at startup - anyone have a fix for this? solihul Defender Technical Discussions 10 December 2nd, 2004 01:39 PM
Oil Light Flickering/Oil Pump Glenn_Guinto Defender Technical Discussions 13 October 27th, 2004 08:27 AM
D-110 Oil Light Flickering?? sharknet Defender Technical Discussions 12 May 27th, 2004 10:06 AM
