Oil leak RH side of 300tdi - Defender Source
Old January 3rd, 2015, 04:33 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I have a small leak that is spraying some oil on the Webasto and the heater box. Not sure where to start looking. Thoughts on what is loose/leaking?
Photo shows the Webasto cover in oil, seems to be coming from something under the air filter.
Old January 3rd, 2015, 04:38 PM
oil cooler line?
Old January 3rd, 2015, 04:57 PM
aosias's Avatar
aosias
Alexandra
1995 D90
That would make sense. Something is off with my oil temp and oil pressure sender too. Maybe (hopefully) it's all connected. It's all happened in the last week.
Old January 3rd, 2015, 05:01 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Vacuum pump when a plug got lost?
Old January 3rd, 2015, 05:05 PM
first thing is to figure out what kind of oil it is.
If it's a 300tdi, it could be diesel as well.
Old January 3rd, 2015, 05:14 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Black diesel?
Alexandra, take some more pix please.
Showing with the cam towards the engine underneath the air filter and some more to the oil filter adapter.
Old January 3rd, 2015, 05:30 PM
shouldn't be too hard to figure out...
Old January 3rd, 2015, 05:41 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
depends somtimes upon the penetration of oil and direction ...
Old January 3rd, 2015, 05:52 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
With the motor running, use a piece of white shirt cardboard and see if you can pinpoint the direction of the oil spray.
It worked for me.
Rent my
Old January 3rd, 2015, 06:04 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Cams aren't able to have a look through cardboards, no?
Old January 3rd, 2015, 06:11 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I vote for the vacuum pump.
300tdi, tdi
Dipstick oil leak 300tdi aosias Defender Technical Discussions 6 April 1st, 2014 10:54 AM
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
300tdi oil leak, main journal? Shane@EVS Defender Technical Discussions 9 May 8th, 2007 06:58 AM
300Tdi oil leak? Gkase Defender Technical Discussions 8 July 24th, 2006 12:13 PM
