Oil Leak..Oil Pressure Switch Failure? - Defender Source
Old December 19th, 2010, 01:39 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
I've had what seems like a massive oil leak the past couple of weaks. At 103k miles I was informed it may be a front or rear main seal. After cleaning it up and changing the oil it appears the plastic tip on the oil pressure switch is cracked (large chunk missing)...and oil is being pushed out the top of the switch. Is this a common failure? Could no exhaust cause this to happen?
Old December 19th, 2010, 02:05 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
It wasn't massive in my case, but I did have to replace a leaky pressure switch a while back.
John Karlsson
Hope Valley, RI
Old December 19th, 2010, 03:16 PM
Grover's Avatar
Grover
Thumbs up
If the switch needs replacing, this would be a good time to replace it with a real oil pressure gauge.
Here is my project:
http://www.defendersource.com/forum/...8&postcount=39
Cheers...
switch
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
