oil leak from 300 tdi - Defender Source
Old April 7th, 2011, 10:38 PM
muhley
matt
110 300 tdi
I seem to be leaking oil from between the engine and trans. First thought is rear main. Could it be something easier? Tried a search for 300 tdi rear crankshaft oil seal but couldn't find any thing. Any thoughts or other threads would be appreciated.
Matt
Old April 7th, 2011, 10:45 PM
rule in or out a head gasket or valve cover leak from the back of the block that could be dripping down the block around the bellhousing to the bottom.
Old April 7th, 2011, 10:54 PM
muhley
matt
110 300 tdi
I'll get a light and mirror for that right now. looked dry from what I could see but I'll double check.
------ Follow up post added April 7th, 2011 10:00 PM ------
valve cover to head is dry, head to block is bone dry. can't think of anything but the rear main.
Old April 8th, 2011, 06:03 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Could be the input shaft seal on the transmission. Not really better.
Tony
1984 110 "Smokey" (sold)
Old April 8th, 2011, 07:15 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Rear main is very common leak, especially it seems at this point in many 300tdi's lives. I have 2 in the shop right now for the same thing. No easy way out. Seal is LUF100430 and the updated gasket ERR6811.....I think, but I'd check that. Fortunately the motor is a pretty easy in - out. Look at the clutch while you are in there and replace the clutch fork.
Also for oil leaks check the intake manifold (not really an oil *leak* but will make a mess). Check the fuel lift pump and the oil pump. both prone to leakage were they mount to block. The oil leaked often gets blown to the back of the block.
Matt Browne
Old April 8th, 2011, 10:40 AM
muhley
matt
110 300 tdi
Thanks for the input guys. As long as the fluid level is checked frequently can I drive it for a month or so, or is there a chance that it could empty the crankcase all of a sudden? It leaves a stain about 3" in diameter right now (after being parked for a while). Again thanks for the help.
------ Follow up post added April 8th, 2011 10:10 AM ------
after closer inspection it looks like(got fingers crossed) it could bu coming from the engine breather filter. the manual has a section an cleaning it. If it is dirty would it push oil out or is it faulty? have you tdi guys dealt with this before?
------ Follow up post added April 8th, 2011 10:12 AM ------
is there anyone who sells the O ring needed to reinstall breather located in San Diego?
Old April 12th, 2011, 10:14 PM
muhley
matt
110 300 tdi
engine breather filter was broken where the bottom hose connects. ordered a new one through brit. pacific. could not figure out which hoses to get though. mine are cracked all the way around on the upper and lower hose to the breather. any guess on part #'s
Old April 12th, 2011, 10:32 PM
Naplm00
Matthew
i just used some heater hose on mine
Old April 13th, 2011, 12:34 PM
muhley
matt
110 300 tdi
I think I'll do the same.
Old April 13th, 2011, 12:39 PM
TS888's Avatar
TS888
Tony Sims
1984 110
You can get oil resistant hose from many auto parts stores. It will last better than heater hose and costs about the same.
Tony
300 tdi, tdi
300 tdi massive oil leak! ideas? discotdi Defender Technical Discussions 11 March 27th, 2009 09:39 PM
300 Tdi fule leak Questions!! Buckon37s Defender Technical Discussions 13 February 28th, 2005 02:32 AM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
