Oil leak are temperature sensor - Defender Source
Old March 2nd, 2013, 04:09 AM
sro
Sam Odio
2008 LR2
I just got my defender back from the mechanic (replaced clutch and transmission) and I'm now noticing a bad oil leak.
It's leaking from the sensor right above the oil filter and oil cooler lines connect. I assume that's the temp sensor?
Is this a common issue? Is there an easy fix? I've tried tightening the nut at the base of the sensor.
Old March 2nd, 2013, 08:33 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
That's your oil pressure sender.
When you went to tighten it, did it feel snug?
Old March 2nd, 2013, 09:04 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
you can try to change the o-ring on the sensor .. becareful not to over tighten you can split the cover if its not already
No Mall crawler here
Old March 2nd, 2013, 10:42 AM
sro
Sam Odio
2008 LR2
It did feel snug. I suspect the cover might already be cracked. The leek seems to be coming from the sensor itself (close to the lead at the end), not the base where it meets the nut.
Old March 2nd, 2013, 10:55 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
O then its just the sensor very common problem with them you can source one locally......
Old March 2nd, 2013, 10:57 AM
sro
Sam Odio
2008 LR2
Local as in autozone / o'reillys? That'll be a relief.
Old March 2nd, 2013, 11:57 AM
navydevildoc
Neill Thornton
Yeah it will be the same part across all of the 3.9 motors, so if they don't show it for a Defender try telling them a Discovery.
A quick check on NAPA's site show it for $14, Autozone is $16.
sensor
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
