Oil leak - Defender Source
Old August 16th, 2015, 09:42 PM
ssi19's Avatar
ssi19
scott
1995/D90
Oil leak
Anyone ever use this stuff to stop the bleeding?
http://lucasoil.com/products/heavy-d...-oil-stop-leak
Old August 17th, 2015, 08:18 AM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
I have used it in my series. It did slow down the leaks a bit.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old August 17th, 2015, 10:35 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Answer is, it depends. Most of these "stop leaks" do so by adding petroleum distillates to your oil in which case the theory is that they will soften your gaskets which helps restore them. As gaskets age they shrink and harden, and if that is the case, they make work. If they are cracked or worn out (not just shrunk) then it doesn't help too much. And it helps rubber, but not things like Viton or Cork gaskets, so it depends on the gaskets. Sometimes they work as advertised, sometimes not. Didn't work in my power steering leak but did help a temp fix of a rear engine seal. Didn't work for my transfer case seal, and that leaked from new.
They typically are not what I expected--I always thought they stopped leaks by being super viscous. That typically is not what they do, although sometimes it is. I think that the power steering stop leak may be a viscous additive is as that comes out like honey...
I would only use such a solution as a temp fix. Seals wear out--replace them before you get surprised...
Old August 17th, 2015, 12:30 PM
ssi19's Avatar
ssi19
scott
1995/D90
Thanks guys
Oil Leak..Oil Pressure Switch Failure? tebby Defender Technical Discussions 2 December 19th, 2010 03:16 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
OIL leak ??? Campbell Defender Technical Discussions 4 November 4th, 2004 12:01 AM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
