Oil leak? - Defender Source
Old August 17th, 2013, 01:38 PM
hotroddef90's Avatar
hotroddef90
Rod Renfrow
1995 Defender 90 ST
Oil leak?
Had an oil change 4 weeks ago at an aamco shop I've never used.
The defender has always leaked a bit (6 months/less than half a quart).
I went out of town for work for two weeks then family vaca for a week so it's now been sitting in my garage and I noticed a pool of oil under the drain pan. I checked the drain pan plug with my hand and it seemed tight but it looks like its coming from the plug.
Suggestions?
Old August 17th, 2013, 01:53 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
They often seem to leak a bit from the drain plug--I tighten mine pretty tight. I doubt they replaced the copper washer, but check to make sure it is at least there and put a wrench on the plug and make sure it is pretty tight. No way to really do much more unless you want to drain the oil.
Old August 17th, 2013, 02:00 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Suggestions?
As suggested by Davis (you gotta love that name), the sealing washer is most likely split or scarred from over tightening and letting oil pass... Since it has little use you could drain the oil into a smallish trash can with a trash bag inside, renew the washer, and refill the engine with the same oil (and probably a little more to replenish what is on the floor and left in the trash bag).
Hope this helps.
RDavisinVA
Old August 17th, 2013, 04:56 PM
I have not used that washer I 8 years.
Old August 17th, 2013, 05:10 PM
Cross threaded by someone who couldn't careless about job quality and is paid to do as many 'hours' as possible?
Old January 5th, 2014, 01:16 PM
Beaver87's Avatar
Beaver87
Alistair Davidson
Ex MOD '86 90 12j
gonna do an oil change on my '86 90 today. Little worried about needing to replace the copper sealing washer...
What size is the washer and can you get it in auto parts stores like O'rielys?
Old January 5th, 2014, 01:34 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
I change the copper washer (genuine) every 3 oil changes, also have the magnetic drain plug nut.
No leaks.
Maybe the shop forgot the washer? (or dropped it)
Old January 5th, 2014, 01:45 PM
Beaver87's Avatar
Beaver87
Alistair Davidson
Ex MOD '86 90 12j
any idea what size they are for the NA?
Old January 5th, 2014, 02:24 PM
More likely someone that is paid hourly and doesn't care about the quality of work. Flat-rate mechanics might take short cuts, but they must attain a certain level of quality, otherwise it would hurt them in the long run. A mechanic doesn't get paid to fix his mistakes typically.
Old January 5th, 2014, 02:26 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Can't tell you the size....but take the drain plug to NAPA. They should have a large selection. I get mine from my local JD dealer.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old January 6th, 2014, 05:09 PM
Beaver87's Avatar
Beaver87
Alistair Davidson
Ex MOD '86 90 12j
Thanks. Oil change complete without a hitch. Turns out mine has the magnetic drain plug too. Whats the for?
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
