Oil gauge and sender upgrade question - Defender Source
Old January 31st, 2013, 07:38 PM
Rover110
Steve
1993 Defender 110 NAS #472
I bought a new VDO gauge. The VDO sender and Parker adapter are on their way.
When I install the sender & adapter do they need any teflon or thread sealant or are they good out of the box?
thank for the feedback.
s
Old February 1st, 2013, 11:13 AM
michael67's Avatar
michael67
Michael White
110 Tdi
I put teflon tape on mine. No leaks so far.
Old February 1st, 2013, 11:28 AM
It depends if they have a separate ground or ground through the housing. If there is not a separate ground, you must not use any sealant.
Old February 1st, 2013, 03:13 PM
Rover110
Steve
Thanks for the input
Old March 30th, 2013, 03:17 PM
Rover110
Steve
Hi All,
I installed the VDO oil pressure gauge. Today I installed the VDO sender and adapter and attached the wire.
The lights on the gauge are connected and working. Below that I have a green/white wire on drives side that is connected as it was before and a white wire on passenger side of gauge with a bullet connector.
Anywhere I try and connect the white wire, that seems logical send the gauge needle to max.
I'd rather not fry anything so any advice would be appreciated.
Where does the wire go? do I have a short?
Steve
ANother strange gauge question? ipgregory Defender Technical Discussions 9 April 8th, 2012 10:29 PM
sender P/N for factory oil pressure gauge 300TDi TS888 Defender Technical Discussions 4 May 28th, 2011 06:56 AM
Temp sender question cgalpin Defender Technical Discussions 8 February 18th, 2011 08:10 AM
diameter/thread of sending units for gauge upgrade jaherring Defender Technical Discussions 3 September 29th, 2005 05:14 PM
Temp gauge sender for '97? Chaucer Misc. Chit-Chat 6 February 24th, 2005 07:47 AM
