Oil Fouling Air Filter - Defender Source
Old April 7th, 2016, 10:41 AM
jashof
Jason Hoffman
1986 90, RHD 200TDI
I have a new to me ROW D90 with a 200TDI. I'm going through it bit by bit, changing fluids, addressing leaks, etc. I changed the air filter yesterday and found it to be soaked with oil. What could the possible causes of this be? I want to start down the path of diagnosing and addressing the root cause.
Old April 7th, 2016, 11:04 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Be Careful. Maybe worn piston rings. The engine could be pressurizing (exhaust gasses moving in the wrong direction) and forcing aspirated oil up the breather, if enough of it gets into the air intake it can start running on its own oil and that's a recipe for self destruction. Google is your friend to find ways to check/trouble shoot. Compression check would be one place to start. Should not be a huge surprise given these engines are old and have a very limited useful life. The good thing is you can unbolt and rebuild it .
Old April 7th, 2016, 11:17 AM
The oil is from the CCV system. Normally you should only get some oil while running, so it goes into the engine and not into the filter.
First check the CCV oil separator as per the manual.
Then check that you do not have excessive blowby.
2.5 NA Diesel Air Filter Box weep oil? josh-man Defender Technical Discussions 14 December 10th, 2014 01:38 PM
Lots of oil in the air filter and now it won't start ceedy Defender Technical Discussions 11 August 2nd, 2014 08:12 AM
Glow plug fouling Jackie Treehorn Defender Technical Discussions 3 June 18th, 2014 09:40 AM
200tdi air filter element and air box bossman429 For Sale - Parts 2 February 23rd, 2013 07:08 AM
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
