Oil/filter recommendations - Defender Source
Old June 21st, 2014, 08:08 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Hi there new to the site and Defenders. I have a 97 Defender with a new motor, 3.9 v8 I believe. I see that Mobile 1 and Rotella are recommended. Just seeing if that's changed. Thanks in advance.
Old June 22nd, 2014, 10:14 AM
Search
Old June 22nd, 2014, 10:22 AM
Modern oils are not the best as they have flat tappets. You want an oil designed for a flat tappet engine. There are a bunch out there. The diesel oils like Rotella were a good choice, but they have recently cut back on the zinc, so it is not as good of a choice.
Old June 22nd, 2014, 10:28 AM
bearskinrug
patrick
lookin
Last I looked the analysis for rotella showed a lower level of zinc although I think there are a bunch of other more modern additives in it to replace the zinc. I have no idea if they are as good or better for the flat tappet design. I think the synthetic rotella has quite a bit more zinc in it and that's what I put in my disco 1. It's in sale right now at autozone in my hood.
Old June 22nd, 2014, 10:41 AM
Valvoline vr1 or Amsoil 10w40
Old June 22nd, 2014, 11:42 AM
Grover's Avatar
Grover
Castrol GTX 10W-30, that's what the pros use...
Old June 22nd, 2014, 11:49 AM
toddw's Avatar
toddw
Todd
Range Rover L405 Supercharged
Chevron Supreme Motor Oil SAE 20W-50
Old June 22nd, 2014, 01:28 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Schaeffer. Making oil since 1839.
Black Rhino Lives Matter
Old June 24th, 2014, 04:46 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Thanks again guys. As far as filters go any recommendations? Or is it just anything that fits?
Old June 24th, 2014, 04:50 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I use Napa gold which is made by Wix.
2.5 NA/2.5TD Fuel Filter head with NIB Filter. hillstrubl For Sale - Parts 3 June 1st, 2013 11:46 AM
2.5 Td - Oil Filter and Fuel Filter gonzanc Defender Technical Discussions 5 November 3rd, 2012 01:38 PM
TDI sediment filter - OEM is Delphi CAV filter? jaherring Defender Technical Discussions 2 October 25th, 2010 03:33 PM
ATF and Engine Oil Recommendations? KKilo23 Defender Technical Discussions 10 October 17th, 2009 10:56 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
