Oil Filter - Defender Source
Old July 25th, 2005, 07:33 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
Oil Filter
I have used Land Rover filters and the Napa Gold filters which seem to be the same length. I recently bought a Fram filter from Walmart and it is about 1/2 to 3/4 inch shorter than the other filters I have used. Did I buy the wrong filter? Does the length matter? It fit on okay and does not leak
Old July 25th, 2005, 07:55 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
It should be OK, but if it were me, I would change to a differnt filter as soon as possible. It has less volume and therefore less media inside and will clog up and not filter as effectively more quickly. I am of the opinion that FRAM filters are one of the worst on the market, from cutaways I have done, and from test results I have seen. I use WIX from my local parts shop, or AMSOIL filters (I am biased as I am an AMSOIL dealer)
Old July 25th, 2005, 08:53 PM
FRAM are garbage the NAPA gold made by Wix seem to be highly regarded and readily availible. NG1068 is what I have been using worry free for a few thousand I guess its doing a good job. less length is less capacity I would imagine.
Old July 25th, 2005, 09:02 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Oh for heaven's sakes. The filter is fine.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 25th, 2005, 09:07 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Does the Napa Gold filter have a backcheck valve in it? I've been trying to find a good, and easily available filter to use without much luck yet. Of all the onse I've tried so far that have the valve, I haven't been totally satisfied with any of them.
K&N's are a serious pain to remove and don't QUITE seal as well as I'd like, Land Rover are pricey and I need to mail order, FRAM Xtra Guard = Garbage but are easy to remove and install.
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 25th, 2005, 09:37 PM
yeah they have the drain back thing. get the 1068 napa gold...
Old July 25th, 2005, 09:38 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Napa 1068 = 100,000 + miles! No runs no drips no prob! Larger than stock & has a cq valve.
Old July 26th, 2005, 08:32 AM
Abrooks's Avatar
Abrooks
Tony Brooks
x2 -- change the oil and filter every 3K and don't worry about the frigging filter . . .
Old July 26th, 2005, 02:24 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
I'm glad you asked, Craig. Some are longer than others, that's just the way it is....
I've done some research on this and have been told that, indeed, bigger is better.
You should always strive for a nice tight fit, and if it's leaking you had better take it in and have it looked at.
Just trying to help,
Rod
Old July 26th, 2005, 07:06 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Rod
"It's not a Jeep"
300Tdi oil filter? artm Defender Technical Discussions 1 April 19th, 2005 06:30 AM
Installing oil cooler thermostat Doug Defender Technical Discussions 8 February 18th, 2005 12:43 AM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
