Oil Drain Plug Size? - Defender Source
Old May 20th, 2015, 12:55 PM
Captain Spalding's Avatar
Captain Spalding
Captain Spalding
Hello all,
I want to install an EZ drain or Fumoto oil drain valve. The Defender is too old to come up on the Fumoto site. I ordered the EZ drain valve as spec'd for the Defender on the EZ Drain site, but the valve they spec'd is incorrect.
Can someone please tell me the correct size of the drain plug threads? I could pull the plug and measure, but I just changed the oil.
Thanks in advance.
Old May 20th, 2015, 01:05 PM
What motor do you have?
Old May 20th, 2015, 01:59 PM
Captain Spalding
Captain Spalding
Sorry, that would be helpful wouldn't it?
4.0L V8
Old May 21st, 2015, 01:23 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
I'm also interested in doing this. If you enter in a 1997, 1998 and 1999 Land Rover Range Range rover you get F106. On Amazon, it says it not compatible. Internet searches is not definitive. I'll check at the mechanics later today.
Old May 21st, 2015, 02:15 PM
What size does it look like or measure to? They used to be 1/2" BSP. A 1/2" NPT will work if that is what it is.
Old May 21st, 2015, 02:16 PM
See here: Search results for: 'drain plug' for different sizes. Each one has a measurement picture.
Old May 22nd, 2015, 04:30 PM
Captain Spalding
Captain Spalding
I've been doing a little research and there may be only one option. Here were my top contenders for oil drain valves.
Left: EZ Oil Drain Valve. Center: Fumoto Drain Valve Right: Femco valve.
The EZ and Fumoto valves operate in the same way, except for the finish. I like that the EZ Oil valve is plated, and has a nice rubber cushion on the valve handle. The handles on both valves are spring loaded into a detent, requiring that they be lifted before they can turn. I think the likelihood of them opening unintentionally is remote. There are other valves I've seen for stationary industrial machinery that don't seem as secure. The versions I've pictured above have an accessory elbow, which I assume anyone with a Defender would choose.
Then there's the Femco drain valve. This is what I believe Difflock.com carries. To use it, first the cap must be removed. The oil doesn't begin to flow when the cap is removed. The oil doesn't begin to flow until you screw on the accessory drain hose. (This means, of course, that you have to buy the accessory hose.) The cap and the check valve provide redundant safeties.
A possible negative for the EZ and Fumoto valves is that you are at the mercy of the way the threads are cut into the oil pan and the valve. When the valves are screwed in, there's no guarantee that the orientation of the valve and handle will be optimal. With the Femco valve orientation's not an issue.
But all that is probably moot. Red90 above suggested that the thread size for the oil plug is 1/2-14BSP. I have no way to be positively sure of that other than to lay my hands on a bolt with that known thread size and try it, but I've looked elsewhere for confirmation and there is anecdotal consensus. I emailed the folks at EZ and Fumoto. EZ drain doesn't make a version with the right threads. Fumoto hasn't gotten back to me. But Difflock has version of the Femco with 1/2x14BSP threads, and they say it will fit a Defender in their product description.
I'm going to order the Femco valve and a right-angle drain hose. I'll report back and confirm whether it's the right size.
The instructions for changing the oil are to remove the cap, screw on the hose, allow the oil to drain into a suitable container, , remove the drain hose, replace the cap, and refill with fresh oil. I might alter the sequence. It might be a good idea to put some replacement oil in before replacing the cap, and check for any oil seeping out of the check valve - to be sure the check valve is not being held open by any debris.
Name:	Oil Drain Valves.jpg
Old May 22nd, 2015, 11:15 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Did you ask the folks at no spill systems?
Old May 22nd, 2015, 11:30 PM
I have a Fumoto 1/2" npt in my truck. Fits no problem. Works great. All my cars have had Fumotos for many years.
Old May 22nd, 2015, 11:34 PM
1/2" bsp and npt are the same diameter and pitch. Only a different thread form. They interchange fine for this sort of application.
Old May 23rd, 2015, 12:00 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You must change your oil an awful lot....
Old May 23rd, 2015, 12:31 AM
Captain Spalding
Captain Spalding
I believe No-Spill and Femco are the same product.
Okay Red, I'm going to trust you on this one. I ordered the EZ-202 NPT 1/2-14. That said, I seem to remember reading once that they interchange fine in one direction but not the other. I don't know which.
You betcha. Every 6 months or 500 miles, whichever comes first.
Old May 23rd, 2015, 02:26 AM
rankar's Avatar
rankar
They are the same. I meant for you to call them and ask because I recall another member buying from them.
Here:
http://www.defendersource.com/forum/...ift-54036.html
drain, drain plug
Changing oil in the R380, do I need to replace a ring like the engine drain plug? bradfordish Defender Technical Discussions 5 September 7th, 2013 08:43 AM
1994 Defender engine oil drain plug size? ollieskins Defender Technical Discussions 2 December 16th, 2010 05:56 PM
where is drain plug for the swivel housing UpnOver Defender Technical Discussions 10 July 23rd, 2007 03:23 PM
Oil pan drain plug thread Pat Defender Technical Discussions 0 June 23rd, 2006 09:02 AM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
