Oil cooler question - Defender Source
Old January 26th, 2015, 08:49 AM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
Oil cooler question
My Tithonus truck came with a front mount oil cooler radiator, but it seems to cool the oil too much and the temperature barely goes up in the gauge. Is that something I should be worried about or should it be fine?
Thanks!
Pablo
Old January 26th, 2015, 08:55 AM
Is that an oil temp gauge or water temp ... if it water temp then you thermostat is probably shot.
If it's really cold where you are you might benefit from a radiator muff.
Old January 26th, 2015, 09:00 AM
PabloCocito
Pablo Cocito
Water gauge goes to the middle and sits there
Oil gauge goes to 1/3 at most..
Right now temperatures seem to idle at 0c (32f) I might have to go with a muff and see how that works.
Old January 26th, 2015, 09:24 AM
I'd think that the gauge is off. Do you have access to an infared aka IR thermometer ? Just shoot the oil pan once warmed up and compare to the gauge. LR gauges aren't known for their quality or accuracy.
Its not possible your oil is 32f with your engine running.
Old January 26th, 2015, 09:30 AM
PabloCocito
Pablo Cocito
I'd think that the gauge is off. Do you have access to an infared aka IR thermometer ? Just shoot the oil pan once warmed up and compare to the gauge. LR gauges aren't known for their quality or accuracy. Its not possible your oil is 32f with your engine running.
I meant outside temperatures haha, yeah I'm gonna try the ir thermometer route. Thanks!
Old January 26th, 2015, 09:37 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Fit a new thermostat to the oil filter housing (erc 5923)
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 26th, 2015, 10:34 AM
jafir's Avatar
jafir
Jafir Elkurd
My oil temp gauge climbs VERY slowly compared to coolant temp, but it does eventually climb, and when it's done climbing it sits above halfway, if I recall correctly.
oil change/oil cooler line change sirjond Defender Technical Discussions 12 January 25th, 2013 03:01 PM
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
Oil Cooler Delete Question Stmpede Defender Technical Discussions 2 May 2nd, 2007 08:17 PM
