Oil cooler pipes - Defender Source
Old May 22nd, 2005, 02:57 PM
sonny reagan
Sonny Reagan
Oil cooler pipes
I am replacing my oil cooler hoses/pipes on my 1995 SW. The old lines do not appear to have the same fittings (at the oil pump housing connection) as the new lines. The exsisting, or old lines, appear to be a part of the oil pump housing itself. If someone can shed light on this job, I would appreciate the info. PM me if you want. I have not yet disconnected the old lines. Thanks. -SR
Old May 22nd, 2005, 03:29 PM
Where did ya get the new ones from? The old ones should screw into an adapter between the oil pump and the oil filter. They may look like they are part of the pump but they should just unthread then pull out. You may want to squirt some penetrating oil on them first to help free them up.
Old May 22nd, 2005, 06:07 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
95.... is that the concentric pump or the gear driven pump?
There are two different types of oil cooler lines, depending on what kind of oil pump you have.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 23rd, 2005, 07:58 AM
95s have the distributer diven pump.
Old May 23rd, 2005, 08:45 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Only some of the 95's have distributor driven pumps, the others are crank driven. You see a bunch of both.
Old May 23rd, 2005, 08:52 AM
I thought it was only Discos that had serp belts in 95? I haven't seen any 95 d90s with serps, but I have only seen a few.
Old May 23rd, 2005, 11:14 AM
nykx
nick
1995 black #2456. 1994 yellow #922
hey there - i just blew out one of those lines on my '95 and decided to replace both. i bought the replacements from rovers north ($86.00/ea. - prt#esr1914, esr1915) it was a pretty simple job - u'll want disconnect the lines and then remove the oil filter and the assemble upon which the oil fliter mounts, which is the same nut that the filter screws onto (i think its a 1.250" socket)...u can then take this whole assembly over to ur ole faithful bench vise and remove the lines (1.062" socket) - be sure to protect the aluminum housing from the vise jaws, itll nick up pretty easily. the whole job took about 15 minutes - it took twice that to clean up all the oil...
good luck!
Old May 23rd, 2005, 11:16 AM
If you pull the cooler adapter be sure to mark it so that it goes on the same way, I am not sure how important it is but the book says to put it on the same way it came off.
Old May 23rd, 2005, 01:10 PM
Hans's Avatar
Hans
Hans Haase
The sandwich plate doesn't matter which way as far as how it rotates, but it does matter which way is up. The exact rotation doesn't matter as long as the pipes connect.
-Hans
My oil line fix
Old May 24th, 2005, 02:41 PM
sonny reagan
Sonny Reagan
Thanks for the information, guys. I confirmed the new oil cooler lines are wrong, they fit a RR and not the D90. If I have further questions after receiving the new oil lines, I'll post here. Thanks again
SR
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil cooler hoses rvrsrvc For Sale - Parts 116 October 16th, 2005 05:47 PM
External Oil Cooler jabber Defender Technical Discussions 3 August 21st, 2005 04:45 AM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
