Oil cooler not circulating - Defender Source
Old April 1st, 2016, 10:09 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
I noticed that the oil never flows through the radiator, the oil will reach the red zone in the highway if I don't keep an eye on it. Is there a diagram that shows where the thermostat is located?
I noticed that the radiator itself doesn't get hot, but one of the pipes coming to the radiator does get hot, could the radiator itself be clogged?
Thanks!
Old April 1st, 2016, 11:58 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Thanks!
Oil and water temp? Or just oil?
pull the radiator and flush it, both for oil and coolant.
Have you checked to see if the oil pump is moving oil? T-stat clear?
Old April 2nd, 2016, 12:07 AM
Thermostat, perhaps it's stuck closed. This is for a 300Tdi, I'm not sure what motor you are running.
Land Rover Workshop Manuals > 300Tdi Defender > ENGINE > OIL TEMPERATURE CONTROL VALVE
Old April 2nd, 2016, 12:21 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Thinking he has the standard Tithonus 2.5NA engine in the truck still.
Old April 2nd, 2016, 12:25 AM
That motor shows a ERC5923 oil thermostat.
Oil Filter with Oil Cooler - Land Rover Workshop
Part number 2
Old April 2nd, 2016, 12:33 AM
We need more info. The oil should never overheat even without and oil cooler. What is the coolant temperature doing?
Which style of oil cooler do you have?
Old April 2nd, 2016, 12:37 AM
PabloCocito
Pablo Cocito
Today I drove it on 495 for a bit, the oil was running hot, and water was at like 3/4th, when I got home I turned the car off and the oil temp gauge went down reallly slow even after the ignition was off. a picture of the oil cooler lines shows that hot oil went through both of them.. So I'm starting to have trust issues with the gauges.. Max block temp was 90c
I don't want to replace all the gauges because I'm swapping them out for a madman ems2 when I swap the 200tdi in. (Just need radiator/intercooler brackets)
ID:	146486   Click image for larger version
oil change/oil cooler line change sirjond Defender Technical Discussions 12 January 25th, 2013 03:01 PM
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
Series Rear Heat Circulating Pump kzack For Sale - Parts 0 August 6th, 2012 10:43 AM
Oil Cooler on D90- To keep or not to keep - that is the question! flananuts Defender Technical Discussions 10 April 25th, 2012 11:24 PM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
