Oil cooler lines revisited - Defender Source
Old July 8th, 2004, 04:50 PM
When removing the oil cooler lines for replacement is it possible for the oil pump loose it's "prime"? perhaps a dumb question but I am not certain. thanks people.
Old July 8th, 2004, 06:39 PM
I would think it is same as when you change your oil.
Old July 8th, 2004, 08:35 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I recently changed mine on my Disco. I had NO problems!
Peter
Old July 8th, 2004, 09:53 PM
thanks thats what I was thinking
Old July 8th, 2004, 10:42 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Phillip,
It is theoretically possible to lose prime if the lines are off long enough. The early engines with the distributor driven oil pumps can have this happen. The newer style front covers used with the serpentine belts where the oil pump is crank driven do not have this problem. I have had a couple of engines lose prime during various repairs such as timing chain replacement...even oil changes if the oil is allowed to drain long enough with the filter off, too. To reprime, I remove the pressure relief valve and fill the oil pump with prelube...as much as you can cram in there ...and fill the filter with oil, too.
Cheers,
Rob Dassler
Old July 9th, 2004, 08:40 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Just don't replicate whatever the Honda techs are doing: http://money.cnn.com/2004/07/09/news...ex.htm?cnn=yes
Still looking: Fitting sizes for oil cooler lines Hans Misc. Chit-Chat 16 February 8th, 2005 08:26 PM
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
