Oil Cooler Lines ESR355 and ESR366 NLA - Adapter Needed? - Defender Source
Old October 10th, 2014, 06:53 AM
delosanasazi
Lawrence de los Anasazi
1963 88 Station Wagon
My 1992 RRC appears to have its original oil lines, which are no longer available. I usually order from parts houses located in the UK.
The lines have bands on each with the numbers ESR0355 one one, and ESR0366 on the other with markings 12 5 92 or 15 5 92 beneath each part number. Maybe these were made on the 12th and the 15th of May in the year 1992.
The fitting ends, all four, are the same, shaped like a mushroom unlike the later types which are sometimes described as a top hat with an o-ring.
Is there an adapter I can use to use later oil cooler lines? Thanks all.
Old October 10th, 2014, 12:34 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Sounds like you have the compression fittings.
I just changed these on my '91 last year although I have no idea why...Range Rover oil lines never burst and catch fire!
I got mine from the usual NA suppliers at the time or Will Tillery...cant remember now.
Rent my
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
LHD NAS and ROW Dash Bits NLA Rubber NLA for now SafariHP Misc. Chit-Chat 1 August 27th, 2009 08:47 PM
oil cooler adapter ring Gore Ranger Wanted 1 June 16th, 2007 02:57 PM
Oil Cooler Adapter O-ring Size dnewman9 Defender Technical Discussions 0 September 5th, 2004 12:30 PM
