Oil Cooler Lines - braided, SS - Defender Source
Old May 5th, 2006, 02:52 PM
DanK
Dan Kunsman
Can someone direct me to a source for braided ss oil cooler lines? I assume that someone is selling these as a kit, but so far haven't found them online. Thank you.
dan
95 Defender SW
Old May 5th, 2006, 04:45 PM
Defender13's Avatar
Defender13
Mike Lynch
1994 Defender 90 #1017
I purchased mine at Trailhead 4 X 4. Talk to Eric, he is a good guy. The kit comes with everything you need. The kit is good for 94 and 95 Defender, but not the 97.
www.Trailhead4x4.com
Old May 5th, 2006, 06:36 PM
saber6's Avatar
saber6
gh
Eddie @ West Coast Rovers. You will not be dissapointed!!! gh
Old May 8th, 2006, 09:48 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Make em!
Old May 8th, 2006, 11:12 AM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
I got mine from Eddie at west coast rovers
Old May 8th, 2006, 11:41 AM
Monkeyboy
Guest
Posts: n/a
I may just be slooowww, but stumbled across http://www.racersrvstuff.com/racersrv/details.php?ITEM=3202538 this morning - it seemed to me that there should be a combination compression fitting / hose barb out there and this listing even says "Replacement for Defender Automatic Transmission Oil Coolers"
I'm off to the hardware store!
KAA
Old May 8th, 2006, 11:58 AM
artm
Arthur Maravelis
97 SW
Keith,
Those are for the tranny, right. Aren't the fittings different for the engine cooler?
Old May 8th, 2006, 12:57 PM
Monkeyboy
Guest
Posts: n/a
Whoops, you're right.
Oil lines are, what 1/2" not 3/8 that the trans lines are - sometimes forget that my '97 is the exception, not the rule as far as transmissions go.
Still, the Rover, nee Buick oil pressures aren't any higher than many home water pressures .... might be worth a look.
KAA
Old May 13th, 2006, 08:59 PM
aloharover's Avatar
aloharover
Peter
1970 Series IIa 105
KAA
Keith,
give Summit Racing a look see.
They carry Earls and AeroQuip hose and ends.
Supper simple to put together and work great.
I am running them for clutch hose, hydroboost/power steering lines, and oil cooler lines.
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Oil cooler lines revisited rover4x4 Defender Technical Discussions 5 July 9th, 2004 08:40 AM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
