Oil Cooler Lines - Defender Source
Old August 1st, 2014, 03:58 PM
gramb001's Avatar
gramb001
JD Gramling
defender 90 ST
Oil Cooler Lines
I'm about to install the new trailhead lines on my 97. Just curious...should I go ahead and drain the oil before installing them?
Old August 1st, 2014, 04:09 PM
yes - this will become obvious when you start the work
Old August 1st, 2014, 09:07 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
...and you'll still get the contents of the lines and the "cooler" tube dumped out too. Don't put that drain pan too far away.
Old August 1st, 2014, 09:19 PM
It makes a mess, but you will only lose about a quart of oil. I've changed a handful without draining the oil.
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Best price on Oil Cooler Lines? bd90 Defender Technical Discussions 9 May 19th, 2004 10:44 AM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
